Anyone ever changed spark plugs???
Old Jun 26, 2008 | 10:55 PM
Nismo350Z_00's Avatar
Nismo350Z_00
Exclamation Anyone ever changed spark plugs???
I have a pretty easy question. Im sure ill be fine, but i plan on putting in the Pulstar Pulse Plugs that i got in the Z and i just wanna ask if there is anything i should watch out for when changing them? I plan on doing it Saturday morning. I just want some advice/tips/how to's from the pros, lol. Thanks in advance.
P.S. I just pull each individual coil up and theres the spark plug right???
Old Jun 27, 2008 | 01:05 AM
NISMO_558's Avatar
NISMO_558
it's alot easier if you remove the top and bottom intake plenum, but you don't have to, and yes, when you pull the coil off the spark plug is right there. Your also going to need a long @ss extension, the plugs are about a good 6-8 inches down in the head.
Old Jun 27, 2008 | 01:08 AM
Spork's Avatar
Spork
I use two 6inch extensions.
Make sure no crap falls into the cylinder.
DO not overtighten the new plugs
Remember to put anti-seize on plug threads.
Old Jun 27, 2008 | 07:21 AM
Thermal1's Avatar
Thermal1
Pulstars huh? get a before and after dyno for us ;-)
Old Jun 27, 2008 | 08:07 AM
laze1's Avatar
laze1
DO NOT change the plugs when the engine is HOT if possible...
you can strip-out the threads removing or installing the plugs.
This problem doesn't happen all the time, just beware that it CAN happen! This is why it is recommended to use anti-seize compound on the threads
Old Jun 27, 2008 | 08:17 AM
CAYENNE2005's Avatar
CAYENNE2005
And then the pattern on putting the plenum back on! If you don't know that already.
Old Jun 27, 2008 | 08:26 AM
Nismo350Z_00
i want to try and do them without pulling the plenum, because like a dumba$$, when i put on my new Kinetix Z Plenum the other day, i didnt think of puttin in the new plugs, lol.
Old Jun 27, 2008 | 08:28 AM
Nismo350Z_00
i have to take off the bolt on the coil before right???
Old Jun 27, 2008 | 09:14 AM
jubes's Avatar
jubes
I say you dont put those plugs in... I think pulstar is a joke seriously.
If anything, I'd only use OEM plugs (which are platinums) or Iridiums (NGK, Denso, HKS, Greddy)... I have the NGK's and I love them, and actually I get really good highway mileage compared to the stocks..
Old Jun 27, 2008 | 09:47 AM
Nismo350Z_00
has anyone tried the pulstars??? am i gonna be the first on eon here, lol. I dont know if i like the idea of that, lol.
Nismo350Z_00
But either way, i spent $134.00 on them, im gonna use them, lol
Old Jun 27, 2008 | 10:31 AM
jubes's Avatar
jubes
wow that's more than the iridiums...
Yeah, I haven't heard anyone using them or atleast anyone posting on here... people have questioned it, but not commenting on their experience with them. So good luck with that..
Old Jun 27, 2008 | 10:46 AM
LeMans 05's Avatar
LeMans 05
And iridiums come from comets. That means it's cool!
Old Jun 27, 2008 | 11:21 AM
j.arnaldo's Avatar
j.arnaldo
...good luck...Tight quarters in that engine bay, dude. Personally, I'll go with
iridium ones, till I get more imput from Pulstar users.
Old Jun 27, 2008 | 11:52 AM
Hoooper's Avatar
Hoooper
thats weird, i thought nobody had ever changed the plugs on a z. thought they were cast in?!?!
Old Jun 27, 2008 | 01:43 PM
cpapasmurf's Avatar
cpapasmurf
This is a simple procedure. I have replaced quite a few plugs on the Z's. You do NOT have to remove the plenem!!!!!!!!! Take the intake tube off it will help to gain access to the rear plugs. Just take your time, remove each coil which is a 10mm bolt then the coil will slide out similar to spark plug wires. Use an extension and spark plug socket to remove the old plugs. Do ONE AT A TIME. Make sure to gap the new plugs prior to install. Just work your way around. It takes time, and the space is very tight but if you have some mechanical knowledge you can do it. Be careful when installing the new plugs and always start them by hand so you do not strip the socket holes. Good luck and make sure to have a few beers while doing the work
Old Jun 27, 2008 | 02:01 PM
jubes's Avatar
jubes
You're kidding, right?
Old Jun 27, 2008 | 06:08 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
search is your friend.
Old Jun 28, 2008 | 05:39 AM
Done Deal DR's Avatar
Done Deal DR
Dude, of course he is kidding! When I saw the thread title I thought the same thing, "No, no one in the history of 350Z ownership has ever replaced the spark plugs".
350z82
Oct 1, 2015 06:25 PM
