Clutch Pedal Adjustment Question
Old Jul 27, 2008 | 11:23 AM
go_speed_engy's Avatar
go_speed_engy
Default Clutch Pedal Adjustment Question
Hello,
I assum many of you are familiar with turning the pin the connects to the "fork" that connect to the clutch pedal in order to manipulate the position of the clutch pedal. I have heard the procedure done two ways. One involves merely rotating the pin. The other involves rotating the "fork". Either of these methods changes the position of the pedal. I am wondering if rotating the pin has additional impacts, specifically, is rotating the pin doing anything else other than moving the pedal, perhaps in a place where I cant see? I realize this is rather vague, but I am going under the assumption that readers will have done this procedure. Thanks!!
Old Jul 28, 2008 | 09:19 AM
go_speed_engy
pretty please?
Old Jul 29, 2008 | 01:45 PM
davidz33's Avatar
davidz33
I tried to adjust the clutch position by playing with rod and fork, but I put everything back to where they were. If I remember correctly, it's the slave cylinder that has a tiny sweet spot, so manipulating from the clutch pedal will most likely end up putting unnecessary stress on rest of the assembly. My suggestion is just keep it the way it is.
Old Jul 29, 2008 | 03:09 PM
Barzten1's Avatar
Barzten1
I totally agree....from experience
Old Jul 31, 2008 | 07:04 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by go_speed_engy
Hello,
get a factory service manual (available on cd on ebay for dirt cheap), set the rod length according to Nissan specs and drive knowing that you're car is setup exactly as it should be.
issyz
Jul 2, 2017 03:04 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
