Stock rear differential cover thickness?
For those of you who have installed a Nismo finned diff cover, or anyone who has had any reason to have removed their stock diff cover, can you tell me the approximate thickness of the cover? I want to tap it for two 3/8" NPT ports, but I'm not sure if the thickness of the cover will allow for a safe number of threads. If the cover is not thick enough I will have to use weld on bungs.
^ Most of the money is in the pump. The cheapest one I can find that is suitable (ie., can handle pumping fluids at high temp) is a Tilton differential pump from summit at around $175.
I priced everything out including all fittings, pump, Earl's cooler.. Came to around $385.
Thanks for the info Stan, I will figure on using weld on fittings.
Yeah, it didn't occur to me that the pump would be so expensive... Don't forget to write down the part number so I can jack it later and follow suit
Let me know if you fawk up your orig diff cover, I should have a few laying around.
Thanks, I will be doing a write up on it when I'm done. I think this will really help keep my diff temps down on the track.
Just to confirm, the diff cover is aluminum, correct?
Here's a few diff install links:
http://flashoffroad.com/Improvements...ase_cooler.htm
http://www.bimmerworld.com/html/diff...uid-cooler.htm
If you want a list of pieces:
Tilton Pump: Part#: TIL40-524 (~ $150)
Derale Electra-Cool Remote Fluid Coolers: Part# DER-15800 (~$150)
Derale Fan Switch: Part#DER-16749 (~$40)
Aeroquip braided steel hose- 12 feet: (~$120 @ $10/ft)
Assorted fittings: ???
In-line filter: ??
Hope this helps.
In-line filter: ??
Hope this helps.
I have my old oem diff cover still laying around after replacing it with the nismo unit. I would say it's probably 1/8" thick. It's cast aluminum. I personally wouldn't try tapping it. Maybe welding on a bung would be a better option...
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
