3.3 lsd in my 04 performance 6 speed...
Old Jul 31, 2008 | 09:26 PM
SnyperZ's Avatar
SnyperZ
Default 3.3 lsd in my 04 performance 6 speed...
How can it be done? Ive searched without luck. What do I need to do(and where can i find)a 3.3 ring/pinion and what aftermarket diff with they go in? Im going big turbo and need the highest gear ratio(lower number for those who dont know) also how would i go about calibrating the speedo? If someone wants to trade with what ive got(not sure what comes in my car its an 04 350z performance 6 speed with VLSD)
Old Jul 31, 2008 | 11:56 PM
kramykram's Avatar
kramykram
it is easier to get a 3.3 differntial, or if you have the 3.3 gears and an auto lsd with axle stubs then you can swap the insides but you will also need to have it built right with the right shims. the speedo reads off the cv axles so no need to calibrate.
Old Aug 1, 2008 | 07:06 AM
SnyperZ's Avatar
SnyperZ
do you know what gears come in my car stock? Maybe I can find someone to do a trade. Also, since its an auto LSD, what aftermarket diffs would fit that?
Old Aug 1, 2008 | 08:53 AM
scmtkings4's Avatar
scmtkings4
yours is a 6 speed, so you have the 3.5
Old Aug 1, 2008 | 11:05 AM
SnyperZ's Avatar
SnyperZ
wow and first gear is still that short..i could never imagine going to a 3.9
Old Aug 2, 2008 | 12:24 AM
bbs350z's Avatar
bbs350z
3.9's are for n/a only. add boost and your gears are useless
Old Aug 2, 2008 | 05:31 AM
SnyperZ's Avatar
SnyperZ
My first gear is so short.. I wonder if steping down from the 3.5 to the 3.3 will really make a big enough difference for the work.
Old Aug 2, 2008 | 08:46 AM
bbs350z's Avatar
bbs350z
from what ive read, yes it does. alberto runs 3.3's, and he seems to love em. shoot him a pm and ask him
Old Aug 2, 2008 | 09:26 PM
SnyperZ's Avatar
SnyperZ
what about aftermarket diffs? Which ones would work with this gear set?
Old Aug 2, 2008 | 10:55 PM
bbs350z's Avatar
bbs350z
depends on what your goals are. some are very unstreetable, while others are very street firendly. im running a stock for now. later should i decide to upgrade, ill go with a kaaz 1.5way
Old Aug 3, 2008 | 01:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
any LSD that works on an automatic would work on the 3.3 - but it has to be an automatic spec LSD, as they are different from manual ones. I know Cusco for example, offers an LSD specifically for automatics
Old Aug 3, 2008 | 06:24 PM
SnyperZ's Avatar
SnyperZ
ahh..well thats a good thing.
Old Aug 4, 2008 | 04:25 AM
Z1 Performance
Former Sponsor
Quiafe offers one for auto's as well - those are the only 2 I know of that work with an auto:
Cusco: http://www.z1auto.com/prodmore.asp?m...ine&prodid=518
Quaife: http://www.z1auto.com/prodmore.asp?m...ne&prodid=2349
Old Aug 4, 2008 | 07:32 AM
SnyperZ's Avatar
SnyperZ
Is it possible to make the cusco a 1.5way? Also, is that for the factory VLSD/auto setup?
Old Aug 4, 2008 | 07:35 AM
Z1 Performance
Former Sponsor
yes the Cusco one is a 1.5 way and is a drop in replacement for the VLSD found in automatics
Old Aug 4, 2008 | 12:32 PM
SnyperZ's Avatar
SnyperZ
it says 2 way..
Old Aug 4, 2008 | 12:36 PM
Z1 Performance
Former Sponsor
it's adjustable from 1.5 to 2 way and vice versa
Old Aug 5, 2008 | 08:29 AM
SnyperZ's Avatar
SnyperZ
Thank you sir.
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
