Fuel Gauge Acting Up!
Old Aug 12, 2008 | 07:39 PM
aguita's Avatar
aguita
Default Fuel Gauge Acting Up!
My Gauge is starting to act up...
Today I topped the tank and my gauge shows 1/2 tank...after 10 mins of driving the gauge started to move slowly to the full mark...after shutting the car off and restart the gauge is showing 1/2 tank again...
I searched but no answers...any help???
The fuel pump was not removed from car...
Is this a Difficult work? I dont want to take the car to the dealer..
Should I remove the Whole Pump assembly to check if a wire or something is messed? Any Instructions on how to remove it? thanks
Old Aug 12, 2008 | 07:51 PM
R-TuneZ's Avatar
R-TuneZ
what would you do if you found a "messed" (up?) wire? would you solder a wire on your fuel pump........ or......
if you do not know what you are doing, i would encourage you to not attempt this procedure.
Old Aug 12, 2008 | 08:33 PM
aguita's Avatar
aguita
Where do i say that i will solder or anything like that...I meant that if there is a pinched wire of something..Btw I wont do anything that i dont know how to...
Old Aug 13, 2008 | 12:25 PM
bbs350z's Avatar
bbs350z
depends how your driving. if you bouce the car around itll read off. maybe the fuel leveler (the white floater on the pump assembly) is damaged or off?
