Help, really weird vibrations/movements in the shifter
Old Aug 17, 2008 | 09:25 PM
sbZenth's Avatar
sbZenth
Default Help, really weird vibrations/movements in the shifter
Today, i was driving around at 80mph at 3000 rpms on the highway in sixth gear.
The shifter was moving around very violently and going up and down. it was traveling maybe a fourth of an inch vertically, and an eighth of an inch horizontally.
What would be causing this...? I doubt its normal...
Im taking my car to the stealership tomorrow morning.
Old Aug 18, 2008 | 07:38 AM
sbZenth's Avatar
sbZenth
bump
Old Aug 18, 2008 | 02:46 PM
sbZenth's Avatar
sbZenth
anyone?
Old Aug 18, 2008 | 04:33 PM
sbZenth's Avatar
sbZenth
nothing?
Old Aug 18, 2008 | 06:14 PM
Spike100's Avatar
Spike100
^^ What happens if you shift from 6th to 5th gear? Do you get the same vibration?
At the speed you are driving (80 mph) with that engine rotation, I wouldn't consider a quarter to an eighth inch as... "The shifter was moving around very violently and going up and down. it was traveling maybe a fourth of an inch vertically, and an eighth of an inch horizontally." ... much outside normal. Just the shake from an uneven roadway would cause this.
--Spike
Old Aug 18, 2008 | 08:31 PM
sbZenth's Avatar
sbZenth
--Spike
when i shift from 6th to 5th, i get some rattle at first, then it goes away. And those distances very conservative. i didnt want to exaggerate. i will take a video soon and post it up.
Old Aug 18, 2008 | 09:07 PM
Spike100's Avatar
Spike100
^^ The video would be helpful to diagnose your problem description.
Actually... I doubt you are outside normal. I would expect some vibration at higher speeds and engine rotation.'
I would suggest the idea you present, and post the video. That might save you the experience of having technicians at the dealership giggling behind your back about this "problem."
--Spike
Old Aug 18, 2008 | 09:28 PM
sbZenth's Avatar
sbZenth
sure thing.
ill take the vid tomorrow and post it.
Old Aug 19, 2008 | 02:40 PM
Zboostin's Avatar
Zboostin
+1 on the video.
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
apex locator
Oct 6, 2015 05:58 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
