solid motor mounts install
Old Aug 25, 2008 | 06:29 AM
bbs350z's Avatar
bbs350z
Default solid motor mounts install
i got a set of solid motor mounts, and read somewhere that the motor doesnt have to be pulled to do this (did a search, couldnt find it). anybody have a diy or link to the original thread? thanks!
Old Aug 25, 2008 | 04:05 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
I believe the motor can jus be lifted using a big jack. make sure its on a solid part, do not lift the motor from the oil pan.
There is no need to pull the motor.
Old Aug 25, 2008 | 07:09 PM
bbs350z's Avatar
bbs350z
jack it from where tho? the oil pan i know would be retarded as hell lol. more towards the front end??
Old Aug 26, 2008 | 09:58 AM
GrayG35's Avatar
GrayG35
dont listen to this guy^^ hes just guessing haha let us know how they turn out if you get them done.
Old Aug 26, 2008 | 10:00 AM
bbs350z's Avatar
bbs350z
yea but i need some input on where to lift! i dont wanna **** up m motor putting it in
Old Sep 16, 2008 | 01:54 PM
OCG35's Avatar
OCG35
what mounts are you using?
Old Sep 16, 2008 | 03:32 PM
ADMAN's Avatar
ADMAN
You lift it from the top...
Old Sep 22, 2008 | 12:41 AM
bbs350z's Avatar
bbs350z
svrtech mounts, and how do i lift from the top??
Old Sep 22, 2008 | 04:47 AM
Jes-Z's Avatar
Jes-Z
^ cherry picker and straps. I've seen it done on most engines that way.
Old Oct 23, 2011 | 06:41 PM
AARONHL's Avatar
AARONHL
What else needs to be removed? I don't even see enough room to put the mount up there.
Old Oct 23, 2011 | 07:56 PM
bbs350z's Avatar
bbs350z
Wow this thread is old lol. Had 2 swaps since that first post lmao
Old Oct 23, 2011 | 10:16 PM
JDMStanced's Avatar
JDMStanced
can you make a DIY?
this would be very helpful
Old Oct 24, 2011 | 12:16 AM
terrasmak's Avatar
The engine will need to be lifted or at least held in place, if you need more room to get them in you can lower the lower eng cradle a bit to get clearance.
Old Dec 29, 2012 | 03:22 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
You use a flat board the size of the oil pan and jack that up carefully.
Old Jan 3, 2013 | 10:44 AM
ericjackson's Avatar
ericjackson
damn i really hope this guy wasnt waiting for a response...
Old Jan 3, 2013 | 10:53 AM
SlowNFurious's Avatar
SlowNFurious
+1 I have held up many motors with a screw jack and a piece of 2x4, although never did it on the 350z.
