NISMO LSD... questions
Old Aug 2, 2003 | 11:08 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Default NISMO LSD... questions
NISMO is offering a new LSD.... questions for those in the know..
1/ What is the difference between 2 way and 1.5 LSD ?
2/ What are the advantages of each over stock LSD in the current Z33 Z ?
thanks...
Old Aug 3, 2003 | 12:18 AM
Topics II's Avatar
Topics II
I dont have all the specs on the nismo differential. But your questions are pretty relative...
1.5 way is only locked on acceleration
2 way is locked on accel and deceleration
1.5way is fine for drag racing or a street car
2 way is good for roadrace, and very good for drift
advantages over stock (i doubt this is a non-clutch type) is the fact that the stock lsd works almost like a traction control, meaning that when one tire starts to spin, the other gets power and starts to spin as well, where a clutch type is always locked together, the only time they are slipping, is when you are at no or very low throttle and they will chatter/clunk, the more clutches, the louder and the more you will feel it, and also the harder it is to break them loose.
I ran a ATS Deftforce (drift 20disc 2way) in my drift prepared RX7. It would chunk so loud that peole thought my driveshaft was slamming into the car or something. but with a slight imput of throttle, the tires would stay locked and it would just chirp the inside tire around the turn (parking lot type stuff).
I also just purchased the Kaaz 24disc diff for my Z. I will be installing it hopefully next week when it gets here. I would not recommend this diff unless you are building a drift Z. The 12disc diff if plenty for anyone. I dont know how many the Nismo has, but my guess is 12-16. Good for a street car, adds predictability to the car, better traction, and if you do 2 way, good lockup on decel.
Old Aug 3, 2003 | 06:10 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Originally posted by Topics II
[B]I dont have all the specs on the nismo differential. But your questions are pretty relative...
WOW! Great info! I printed this out for my file, thanks.
Old Aug 3, 2003 | 09:08 AM
fdao's Avatar
fdao
Awesome info! Thanks!
Old Aug 3, 2003 | 10:29 AM
John's Avatar
John
Sort of. A 1.5way will lock partially on deceleration, while a 1 way locks on only acceleration. With a 2 way, the car can push more than you want it to, so you need to be careful on the ramp angles you choose in the LSD.
Here are some good links on the subject:
http://www.icpcitation.com/variloc_theory.htm
http://www.icpcitation.com/variloc_tuning.htm
Old Aug 3, 2003 | 10:51 AM
jeffw's Avatar
jeffw
What do you all think about Torsen/worm gear style diffs versus clutch types? What are the advantages and disadvantages of each?
Thanks,
Jeff
Old Aug 3, 2003 | 11:57 AM
John's Avatar
John
Torsen types are much more reliable, but aren't as effective on a road coarse as a good 2-way clutch type diff.
Old Aug 6, 2003 | 12:48 PM
Topics II's Avatar
Topics II
Also good info sir... touché...
Old Aug 6, 2003 | 03:40 PM
Traffic's Avatar
Traffic
Thanks,
Jeff
Kind of a moot point; there are no gear-type differentials available or even in development for the Z.
Only disadvantages to a clutch-type are having to change the oil and the occasional clunk or pop from the drivetrain. I have the Kaaz 2-way on my car and it's very streetable, streetable enough where my g/f can drive the car with no problem. Around a turn, I can make the back end step out very predictably, plus the car hooks up well in a straight line; it's a HUGE improvement over my stock open diff.
But I would say if you don't intend to be drifting or tracking your Z, there's no reason to ditch the VLSD that comes standard. The sotck VLSD will do just fine for most purposes. It's $~1000 that could be better spent somewhere else in the car.
Old Aug 7, 2003 | 01:18 AM
apex locator's Avatar
apex locator
daytona,
do you drift your 350z?
Old Aug 7, 2003 | 02:54 AM
Topics II's Avatar
Topics II
Originally posted by b18bvudoo
daytona,
He should.
New Brunswick is about 30min from Englishtown, NJ. Which is where we hold monthly drift events. (Soon to be bi-monthly )
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
