Help: Engine shutting down!
Old Sep 18, 2008 | 04:57 PM
antoz's Avatar
antoz
Default Help: Engine shutting down!
Something weird happened to my car. I have 40K on the odometer. Today I started my car and let it warm up. Then I went to the bank and turn off my car. When I came back and started the car, the engine started just fine but then the rpm's started to drop until the engine died. I started the engine again and the same thing happened! I had to press the gas pedal to keep the rpm's up for like 10 secs and then it was fine again. My car is stock (No spacer, no Intake, etc)
Have any of you experienced this before?
Do you know what could be wrong?
Old Sep 18, 2008 | 05:42 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
start with the simple stuff...check for any vac leaks, air filter. Might pay to do the idle relearn feature as well. Sorta hard to diagnose
Old Sep 18, 2008 | 11:03 PM
ADMAN's Avatar
ADMAN
+1 on Idle Reset or something stuck in your intake.
Old Sep 19, 2008 | 09:32 AM
__jb's Avatar
__jb
Z + Rear Seat
Check the oil.
Old Sep 19, 2008 | 01:22 PM
antoz's Avatar
antoz
Originally Posted by __jb
Check the oil.
What do you mean? The level of oil?
Old Sep 19, 2008 | 02:54 PM
__jb's Avatar
__jb
Z + Rear Seat
A friends G started doing something similar and it turned out he was out of oil and the engine seized. He had the oil consumption problem and never knew it.
I'm just saying to make sure you have enough oil in the car.
Old Sep 23, 2008 | 04:04 AM
BiGGD198's Avatar
BiGGD198
how do you do the idle reset? unplug battery and let sit for 15 min so ECU resets? i have the same problem, but its just a sudden bog...if i rev to 2k on start up, it drops normally.
Old Sep 25, 2008 | 08:29 PM
R-TuneZ's Avatar
R-TuneZ
the first thing i would do (after checking oil levels...)
http://www.technosquareinc.com/350reset.htm
Old Sep 27, 2008 | 10:36 PM
Z12350Z's Avatar
Z12350Z
Had the same issue buy electronic parts cleaner or maf cleaner ( Mass Air Flow Sensor) Take your maff out and spray inside of the maf let it dry put it back in start car let me know what happens
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
