ACT Clutch
Old Oct 5, 2008 | 02:43 AM
DJShan209's Avatar
DJShan209
Default ACT Clutch
I currently have a TN Set up at 370 WHP and 400 WTQ
This is my DD, the question i had was i was looking for a good DD clutch that could hold up my power and still be able to drive around town with.
Was thinking of going with the ACT Street clutch but after reading some posts it seems that a lot of the guys with F/I with the same power level are running 6 Puck, not sure if its the right decision to make or not.
I also wont be upgrading the flywheel, just clutch.
Please chime in, Thanks!
Old Oct 5, 2008 | 07:48 AM
All 6 puck clutches are not created equal. The disc above for example is “sprung.” You can see the springs in the disc. The springs reduce some of the shock to the drive train when the clutch is engaged and disengaged.
Above is a no-spring disc. Not quite as street friendly as a sprung disc.
A spring vs a no-spring disc is not better or worse. Just different.
Old Oct 5, 2008 | 01:24 PM
DJShan209's Avatar
DJShan209
Thanks for the reply and example David, looks like the sprung would be more ideal for street rather than the unsprung which could be more ideal for perhaps a more race set up. Im still not sure if a 6 puck is needed for my power levels and if i get away with a ACT Sreet clutch which holds up 455 TQ
im looking for minimal if not at all any slippage. Im also not sure if i should go with a flywheel as well (Prolite from ACT) my car is my DD but i also want it to perform good at the dragstrip which is the only type of racing that i do so no autoX, drag, circuit etc.
Thanks in advance.
Old Oct 5, 2008 | 03:44 PM
Thanks in advance.
Clutches are a toss-up. A 6 puck clutch grabs and grabs fast. It will not slip. On the downside it is not as street friendly as the OEM clutch.
Old Oct 5, 2008 | 03:50 PM
diwun67's Avatar
diwun67
+1 I have an ACT 6-puck and it grabs fast and hard...and it's a sprung hub too...I don't even wanna think what an unsprung would be like on a street car
I drive mine everyday too and it has almost 20k miles on it. Although the pedal is considerably stiffer than stock, I love it I've beaten the **** out of it at the drag strip and it takes the abuse like a champ, so no complaints here.
Old Oct 5, 2008 | 06:34 PM
DJShan209's Avatar
DJShan209
Exactly what i was looking for thanks
also did you upgrade your flywheel?
and i know this isnt the drag section, but im running a very similar set up as you are, and was wondering if you ran that 12.3 with street tires or a DR set up?
Old Oct 6, 2008 | 12:37 PM
raf84ny's Avatar
raf84ny
ACT Clutch Kit – Heavy Duty Pressure Plate with 6 Pad Spring Centered Race Disc
Torque Capacity: 582
ACT Clutch Kit – Heavy Duty Pressure Plate with Performance Street Disc
Torque Capacity: 455
SO, Performacnce Street Disc should be fine for your torque.
ACT XACT Streetlite Flywheel ( 16.9 lbs )
ACT XACT ProLite Flywheel ( 13.2 lbs )
Old Oct 6, 2008 | 04:05 PM
DJShan209's Avatar
DJShan209
Thanks again for the replies!
Looks like ill be going with ACT 6 puck sprung clutch with a ACT Streetlite Flywheel.
Old Oct 6, 2008 | 08:11 PM
diwun67's Avatar
diwun67
yes, Fidanza 13 lb flywheel. The 12.3 was on DR's with a weaksauce 1.84 60ft. I nailed a 1.5 60ft before that, but popped a coupler and lost all boost
Old Oct 9, 2008 | 09:28 AM
maximariceboi's Avatar
maximariceboi
i love my act 6 puck sprung clutch with havey duty pp on my maxima with a vq35 swap..grabs really nice...using that as my DD and N/A set up =/ over kill but boosting soon to make some use out of the clutch =]
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
