Unorthodox Racing Pulllys Question!!!
Old Oct 11, 2008 | 09:25 AM
350z 7k's Avatar
350z 7k
Angry Unorthodox Racing Pulllys Question!!!
So i recently installed these pulleys on my z and now every time on a cold start my belts scream like a cat dying. I tighten the belts again and it still seems to do it. Only on cold start for about 30 sec.
Old Oct 11, 2008 | 09:27 AM
godmans's Avatar
godmans
get the belts tightened, if you don't have experience or a gauge to measure the tightness, get a shop to do it. It should be a good and easy 30 mins job.
Old Oct 11, 2008 | 09:30 AM
citymunky's Avatar
citymunky
I have my pulleys for over 2 years, and I have no cat dying in my engine bay.
Old Oct 11, 2008 | 09:32 AM
Steve-O Z33's Avatar
Steve-O Z33
If all else fails, spray some belt dressing on the belt with the engine running. That used to work on my eclipse and keep the squeal away for a while.
Old Oct 11, 2008 | 09:36 AM
raf84ny's Avatar
raf84ny
HAHAHHAHAH ! LOL
Old Oct 11, 2008 | 03:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not recommended at all
your belts might feel tight, but they aren't - get a factory service manual, it's got the specs for belt deflection (how much you can push down on them to know they are tight)
Old Oct 11, 2008 | 04:10 PM
citymunky's Avatar
citymunky
If all else fails, spray some belt dressing on the belt with the engine running. .
Old Oct 11, 2008 | 04:13 PM
cdoxp800's Avatar
cdoxp800
No issues here..
Old Oct 13, 2008 | 10:43 PM
cpapasmurf's Avatar
cpapasmurf
Scott
So what belts are you using? I would start with making sure the pulley's are tight, and straight...Make sure that the belt is not too tight, or too loose. Sometimes the belts stretch, or just do not sit right in the pulley, in this case I would go with alittle better belt. The only other option is to put some synthetic grease on the bottom side of the belt, this is only going to stop the noise for a short time. If you can't get it fixed run it by my shop and we can take a look at it.
Old Oct 13, 2008 | 10:52 PM
lbz's Avatar
lbz
Mine howled like a panther passing a kidney stone at first, but a little tightening and it's all good.
issyz
Jul 2, 2017 03:04 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
