New engine - idle problem
Old Oct 13, 2008 | 08:51 AM
latin_racer's Avatar
latin_racer
Default New engine - idle problem
So my car got a new engine and At idle, the car thumps or shudders slightly. every few seconds there is a little tach fluctuation drop and it comes back up. just thumping or slight shuddering. It drives fine. It's only when i'm at a light or parked in idle. Any suggestions? Only mod I have is the jwt pop charger and It didn't do this with the previous engine.
If it's an easy fix I rather do it myself then to take it back to the dealership and have to wait a few hours for it.
Old Oct 13, 2008 | 10:42 PM
mastercater7's Avatar
mastercater7
Try adjusting the IACV and make sure your vacuum lines are tight
Old Oct 14, 2008 | 03:02 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Damn noob as there is no adjusting the idle air control valve on this engine.
Old Oct 15, 2008 | 05:47 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
You can try this....
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
