What is a Air/Fuel Ratio Sensor?
Old Nov 2, 2008 | 01:05 AM
superz2004's Avatar
superz2004
Default What is a Air/Fuel Ratio Sensor?
I got a P1273 - Air/Fuel Ratio Sensor 1 CEL a few weeks back. My Z is stock with nismo CAI, nismo exhaust. I have had the these mods done awhile back with no problem.
I went to Nissan to get a Air/Fuel Ratio Sensor and they said it is a heated oxygen sensor. I replaced that but the code P1273 still comes up? Is there any other components i need to check? With Vacuum leaks - Where would i start looking for it?
Any help is appreciated!
Old Nov 2, 2008 | 01:58 AM
Z04's Avatar
Z04
your car is not "stock" with those mods on it. you need to clear out the code yoruself or take it to nissan and have them do it
Old Nov 2, 2008 | 11:30 AM
BrazenZ's Avatar
BrazenZ
Well I'd would say his car is pretty close to stock. When I modified my exhaust and CAI it did'nt cause any 02 sensors CEL to go off. Go back to Nissan an tell them it isn't fixed.
Old Nov 2, 2008 | 06:08 PM
superz2004's Avatar
superz2004
I already resetted the ecu using the manual way of doing it via several websites like thru technosquare. The CEL still shows.. HELP! Do i have to take it to the dealership or do i still have a problem?
Old Nov 3, 2008 | 09:22 AM
BrazenZ's Avatar
BrazenZ
1) OEM AFR sensors are heated O2 sensors. If you have replaced yours @ Nissan take it back the them. They might give your crap about having an aftermarket exhaust system saying that you have an exhaust leak causing the problem. Don't believe it unless they can show you where the exhaust is
leaking.
It could be something as simple as loose connection on the O2 sensor.
2) If vacuum leaks were the problem, It almost always triggers a PO300 cel (random misfire)
Old Nov 3, 2008 | 12:48 PM
superz2004's Avatar
superz2004
Thanks for the vacuum tip BrazenZ.
Old Nov 4, 2008 | 10:26 AM
rcdash's Avatar
rcdash
Exhaust leak?
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
