Twin Carbon Clutch on 540WHP
Old Nov 6, 2008 | 11:03 AM
jl4punch2's Avatar
jl4punch2
Default Twin Carbon Clutch on 540WHP
So I am moments away from buying a 2007 G35 TT with JWT 700BB and built motor from FP and I find out the clutch is slipping.....
This is the owners response.....True or False???
"The deal on the clutch is that it is a twin carbon clutch designed for the drag strip. It slips if you run max HP at high RPM if it is not warmed up properly. I first thought something was wrong with it, but after to talking to people that know how these clutches work, I found out the issue was that I was not doing the warm up procedure which is to slip the clutch a couple times for a few seconds. Now that I know how to warm it up, I don't have the problem."
What do you guys think about this???
Old Nov 6, 2008 | 12:09 PM
iamdigital's Avatar
iamdigital
Save the money and buy the other car APS and black cars FTW
Old Nov 6, 2008 | 12:18 PM
Zivman's Avatar
Zivman
a twin disc carbon clutch will slip if not properly warmed up. that said, I have heard VERY mixed reviews of the GTM spec exedy.
Edit:
FYI, the D-core twin disc exedy is the clutch to get if getting an exedy. I personally run a twin disc ATS with the HD pressure plate. I have only had one instance of noticing the clutch slipping due to it being cold...
Old Nov 6, 2008 | 04:21 PM
jl4punch2's Avatar
jl4punch2
Edit:
So the warm up process includes "slipping" it five times within 30 secs
Old Nov 6, 2008 | 04:22 PM
jl4punch2's Avatar
jl4punch2
I would like to add, it only slips if not warmed up
Old Nov 6, 2008 | 04:50 PM
Zivman's Avatar
Zivman
I just drive mine around a bit. I don't follow a detailed warm-up regimen
Old Nov 6, 2008 | 05:01 PM
JETPILOT's Avatar
JETPILOT
That's bs.. I have never had a carbo clutch slip on me and I have had 3. If it is slipping it means it is time for a new one.
Old Nov 6, 2008 | 05:40 PM
jl4punch2's Avatar
jl4punch2
Im pretty sure its even on their site, Proper warm up instructions etc.. It doesnt do it all the time and has never done it after warm up. Ive heard from a few people that its pretty common but maybe not
Old Nov 6, 2008 | 05:54 PM
Jason333's Avatar
Jason333
hi
Mine can / has slipped if not warm
Old Nov 6, 2008 | 06:05 PM
jl4punch2's Avatar
jl4punch2
So do you warm it up by "slipping" it five time back to back or do you just drive light until you've made some shifts??
Old Nov 6, 2008 | 06:08 PM
JETPILOT's Avatar
JETPILOT
That's only for the R-compound clutch discs, and they should not slip at high RPM.
Old Nov 7, 2008 | 07:20 AM
jl4punch2's Avatar
jl4punch2
Its an Exedy GTM Spec Twin Disk Carbon Clutch
Old Nov 10, 2008 | 04:22 PM
mwetzel's Avatar
mwetzel
You are incorrect. This is my car that is being discussed. Here is the link from Exedy:
http://www.exedyusa.com/race/race_content.asp?id=18
This refers to their twin carbon clutches. From that page:
Warm Up Procedure
Due to the inherent properties of the carbon material, we must specify the proper way to bring the discs up to operating temperature. This Process will heat the discs so they will hold the specified torque rating. The correct method is three, five second “slips” of the clutch within 30 seconds at low RPM.
If the warm up isn't done the clutch will slip when the turbo reaches peak boost and then as the torque decreases it catches again. This is consistent with what they describe on their own website "so they will hold the specified torque rating".
You said you have had three of these. How many were from GTM / Exedy?
Old Nov 11, 2008 | 05:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
My clutch has only slipped 2X in over 10,000 miles of abuse. Only happened when the clutch wasnt warm and I threw a quick shift. I dont even heat it up at the drag strip anymore because when you heat them up, they actually grab too hard IMO. I have a triple but it's the same concept.
Jet is incorrect in saying if a carbon clutch slips that you need a new one, he just cant shift fast enough There is a big difference between it slipping under WOT, and the clutch slipping after a fast shift when cold....if it's the ladder, you are likely fine.
EnjukuRacing
Sep 30, 2015 06:55 AM
