2005 mt z and impossible to shift in reverse in cold weather
Old Nov 12, 2008 | 11:54 AM
alan86's Avatar
alan86
Default 2005 mt z and impossible to shift in reverse in cold weather
Even after warming up for 10 minutes in the morning, its either impossible or very hard to get into reverse. I have 38k miles and hav all the service done I.e oil changes and major tuneups. I'm wondering do I have to change the tranny fluid? Or is it the 05 tranny itself? Lmk, thanks.
Old Nov 12, 2008 | 07:56 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Try...
Put in first gear, and then move to reverse.
Old Nov 12, 2008 | 08:08 PM
redman333's Avatar
redman333
What happens when you put it in reverse?
Old Nov 12, 2008 | 08:32 PM
alan86's Avatar
alan86
it wont shift into reverse, it feels locked from the neutral position.
Old Nov 13, 2008 | 07:36 AM
Master Shake's Avatar
Master Shake
Originally Posted by alan86
...Or is it the 05 tranny itself?
I have this problem with 2nd gear, but not reverse. 2nd gear doesn't work when it's cold (not even with a double-clutch) -- but is fine after the trans warms up. Not sure if this qualifies for any kind of warranty work or not. Do you know what weight your trans oil is?
Old Nov 13, 2008 | 08:36 AM
Asterix's Avatar
Asterix
New tranny oil will help this, if you are still running the original goo. Oil better than Nissan's will help even more. The car just sitting still and idling doesn't warm the transmission much at all.
If it's really stubborn, let the car roll a little or move the car slightly in 1st, then try again.
Asterix
Old Nov 13, 2008 | 11:47 AM
Asad_A203's Avatar
Asad_A203
Originally Posted by Hohuyoo786
the secret of success is constancy of purpose.Come and buy wow gold, Warhammer gold, wow gold, wow power leveling, Warhammer power leveling web .
^ HAHAH. Spammers are becoming more and more creative.
Old Nov 13, 2008 | 03:58 PM
BiGGD198's Avatar
BiGGD198
ehh...creative....yes, annoying....VERY...haha
Old Nov 13, 2008 | 04:17 PM
jesse&alaina's Avatar
jesse&alaina
yea you new tranny oil will help you need to change it at least every 30,000 miles or so and dont forget your differential gear oil either
Old Nov 14, 2008 | 12:06 PM
Bevo's Avatar
Bevo
If you didn't replace your tranny fluid at 30k miles, it's time to do it now.
Old Nov 14, 2008 | 06:41 PM
Transmission fluid will not fix a transmission.
If the transmission will not go in reverse then it must be broken.
Old Nov 15, 2008 | 09:50 AM
alan86's Avatar
alan86
yea i've had the tranny oil replaced at 30k. the thing is that i know its not broken because in hot weather, i can shift into any gear fine.
Old Nov 15, 2008 | 08:22 PM
carlos305's Avatar
carlos305
I had the same problem a while back, so i took it to Nissan so they can replace the tranny oil and that worked for a little while then it started to happen again so i adjusted my clutch's engagement point. I put it a little higher and now it works perfect... you should try it, it worked for me
http://www.specialtyz.com/clutchadj.htm
Why does "35oz-tech" come out as ********* ?
Old Nov 15, 2008 | 08:27 PM
alan86's Avatar
alan86
cool thanks! i did adjust this lower a while back, i think thats it!!
Old Nov 15, 2008 | 08:31 PM
carlos305's Avatar
carlos305
if you've adjusted it before than i'm 99% sure that you went too far and that why it doesn't let you go into reverse .
Old Nov 15, 2008 | 10:20 PM
Acidhex's Avatar
Acidhex
Not trying to be a smart ***, But since no one has touched on it.. you are pushing down on the shifter before moving into reverse aren't you?
Old Nov 16, 2008 | 02:15 AM
alan86's Avatar
alan86
of course! i found out that the problem is the clutch engagement point. i adjusted it a while back since the pedal was too far up. i've adjusted it too low so that the gears are technically engaged even before i engage the clutch. thanks for your help!!
Old Nov 16, 2008 | 10:12 AM
Acidhex's Avatar
Acidhex
Ah, great! Glad you got it solved
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
