New Clutch and Flywheel and Installation
Old Nov 24, 2008 | 01:05 PM
GSTERLING79's Avatar
GSTERLING79
Default New Clutch and Flywheel and Installation
Just installed new stage 3 clutch and flywheel in 2003 z, now cars engine wont start. Do i need to change my speed sensor?
Old Nov 24, 2008 | 01:11 PM
kacz07's Avatar
kacz07
sounds like you made a booboo
Old Nov 24, 2008 | 01:29 PM
Dr. Venture's Avatar
Dr. Venture
well there is only one way to install the flywheel, so i don't think u made a signal timing error. Did you pinch any wires when installing?
Old Nov 24, 2008 | 06:10 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you either damaged the crank sensor, or forgot to plug it in
Old Nov 25, 2008 | 02:32 PM
thierry75's Avatar
thierry75
I'm having the same problem...took my car in (06 base coupe MT) to the nearest dealership to have the clutch/flywheel replaced and now the car won't start...
Could it be a bad flywheel? they're putting a new one in to try and figure it out...The engine cranks over but won't start...
Any thoughts?
Old Nov 26, 2008 | 04:57 AM
Z1 Performance
Former Sponsor
same issue more than likely ^
the flywheel isn't bad...it can only be installed 1 way. There are ring gears that are either pressed on, or part of the flywheel itself that the crank sensor reads. If the sensor is damaged during install (common) or not connected (common) the car will never start again, it will just crank and crank
Old Nov 26, 2008 | 05:34 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
+1. My guess would be they didn't line up the dowel pin correctly....but it could be either issue.
Old Nov 26, 2008 | 05:38 AM
Dr. Venture
You can narrow it down by checking what you don't have. SPARK or FUEL. Then see if it is the Crank Sensor or the Cam Sensor which one or the other controls and go from there. Most likely you have no spark and it is the crank sensor giving you an issue.
About $70 bucks new.
Old Nov 26, 2008 | 11:40 AM
kramykram's Avatar
kramykram
you can also jack up the car and take the crank sensor out and have shine a flashlight in the crank sensor hole. have someone turn over the car and see if the flywheel looks like it woobles a little. if it does then they didn't line the dowel pin up as stated above. but it will look like it is wobbling or lopsided.
Old Nov 27, 2008 | 07:24 AM
thierry75's Avatar
thierry75
Any thoughts?
Turns out my issue was with the engine...namely that I needed a new one...
Thank God it was still under warranty...phew! I'll miss her for the next week but I'm actually looking forward to a whole new drivetrain...
I hope it's not the case with yours...good luck!
Old Nov 27, 2008 | 07:33 AM
Z1 Performance
Former Sponsor
so you're car went to the dealer needing a new clutch and left (or tried to) needing a new engine? And you're actually letting that dealer do the work? I wouldn't let them vacuum my floor mats at that point. What happened between point A and B that a new engine is necessitated
Old Nov 27, 2008 | 04:59 PM
Sharif@Forged
Forged Performance
I am glad you asked the question, so I didn't have to...LOL.
Old Nov 27, 2008 | 06:59 PM
guitman32's Avatar
guitman32
Sounds like they let a newb tech wrench on your car. Avoid dealerships like the plague.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
