Reading ECM Harness voltages
Old Nov 29, 2008 | 02:48 PM
App6MT's Avatar
App6MT
Default Reading ECM Harness voltages
So here's the diagram from the service manual:
I'm trying to check the voltages for the "Power Supply for ECM", which is pins 119, 120. The manual states that it sound read 11-14V with the Ignition Switch: ON.
Also, 121 is the backup for the power supply, which should read 11-14V with the Ignition Switch: OFF.
Ok so my question is, do I read this directly from the harness? What I did was disconnect the harness from the ECU, and try to test the actual connector. However, it doesn't seem to be working that well. So do I need to plug the harness back into the ECU and tap into the individual wire?
Old Nov 29, 2008 | 04:58 PM
App6MT's Avatar
App6MT
The answer is you can check it with the ECM harness taken out of the ECM.
Problem was with the wiring diagram was completely *** backwards from what the actual harness looked like.
apex locator
Jul 23, 2021 02:27 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
