Rear coolant by pass kit..Does this work?
Old Dec 2, 2008 | 06:11 AM
ZmanAlex's Avatar
ZmanAlex
Default Rear coolant by pass kit..Does this work?
http://www.forgedinternals.com/store...cat=316&page=1
As per the title, any of you guys had any experience with this.?
I am running a 600 bhp Z and was considering fitting this as an aid to keep the coolant temps down.
Any advice would be appreciated.
Thanks,
Alex.
Old Dec 2, 2008 | 06:29 AM
SSZVirginia's Avatar
SSZVirginia
You waited three years to make a post?
Old Dec 2, 2008 | 06:32 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yes they do work. Motordyne sells them too.
Old Dec 2, 2008 | 07:47 AM
ZmanAlex's Avatar
ZmanAlex
Oh! so I did, How time flies
Yeah, based in Scotland mate and I am quite active on the U.K.forums but time is the issue.
I am sorry that my first post is to seek advice, hope that you don't mind.
Old Dec 2, 2008 | 07:49 AM
ZmanAlex's Avatar
ZmanAlex
Cheers mate, thanks for that.
Old Dec 2, 2008 | 08:26 AM
SSZVirginia
Not at all. Always welcome the overseas influence.....
Old Dec 2, 2008 | 03:29 PM
WTX350Z's Avatar
WTX350Z
I hope that's sarcasm. cause if so its hilarious!
Old Dec 2, 2008 | 03:40 PM
westpak's Avatar
westpak
SFZCC
not the same thing
Old Dec 2, 2008 | 04:00 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Never said it was the same thing, he does sell coolant bypass kits though.
Old Dec 2, 2008 | 05:07 PM
westpak's Avatar
westpak
SFZCC
well he was asking about one thing and you suggest another unrelated one.
it's like someone asking about oranges at store A and being told that store B sells apples
Old Dec 3, 2008 | 05:54 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the thing motordyne offers is to control the coolant flow to the throttle body - it does not help cooling whatsoever, it just allows you to turn on or off the coolant passage - like a faucet
the kit that the OP is asking about is made up of a series of parts, and allows better coolant flow from one head to the other at the rear section of the engine, with the addition of a new cross pipe with integrated thermostat
ZManalex - highly recommended for big power cars, as it really does a great job of keeping temps more consistent head to head
Old Dec 3, 2008 | 06:19 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Again, Motordyne offers another type of bypass kit. I never said it was the same type. Since he was interested in getting better cooling, everythign helps.
Old Dec 3, 2008 | 07:25 AM
Z1 Performance
Former Sponsor
edit, nevermind - what you are talking about and what I mentioned above are the same thing. Motordyne has a CCV (coolant control valve) that installs at the throttle body. It lets the user prevent, or allow the flow of coolant to the throttle body (the factory setup allows for coolant to flow to the throttle body). It has nothing to do with what the OP was asking about though, and really doesn't offer better cooling for the engine - it can make for a slightly less messy install though
Old Dec 3, 2008 | 09:25 AM
ZmanAlex's Avatar
ZmanAlex
Thanks for that Adam,
I should have bounced this off you on the Z U.K.forum, just never thought mate.
I have ordered one up anyway as every little helps.
What about the thermal gasket for the bottom of the plenum, does this help a bit as well?
Cheers,
Alex.
Old Dec 3, 2008 | 09:27 AM
ZmanAlex's Avatar
ZmanAlex
Yeah, I had looked at this previously mate, thanks.
Old Dec 3, 2008 | 09:32 AM
Z1 Performance
Former Sponsor
Cheers,
Alex.
it cant hurt I'm sure, but I stick to OEM when it comes to gaskets - cheap, easy to get
Old Dec 3, 2008 | 09:39 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
I have it, it works good. Here in Florida engine temp is an issue for a lot of us boosted guys so I would recomend it, but I am not sure how much of an issue it is in the freezing country of Scotland
Old Dec 3, 2008 | 10:04 AM
ZmanAlex's Avatar
ZmanAlex
Are you referring to the rear coolant by pass kit or the thermal gasket.?
Yeah! minus 5 degrees C tonight, that's about 20F isn't it.
Old Dec 3, 2008 | 10:06 AM
ZmanAlex's Avatar
ZmanAlex
Even oem head gaskets???
Old Dec 3, 2008 | 10:07 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
the bypass system.
