Difference between pumpkin.
Old Dec 23, 2008 | 09:35 AM
bovi's Avatar
bovi
Default Difference between pumpkin.
Hi guys, im planning to swap a OEM full pumpkin on my base non-lsd Z. Theres so many specifications i dont understand. Like the 3.3 and 3.5 , which is better for what use???
I start to search but nothing is fully explained.
If you guys can gimme an answer please.
Thanks
Kevin
Old Dec 23, 2008 | 11:04 AM
bbs350z's Avatar
bbs350z
Thanks
Kevin
those are the final drive gear ratios. 3.3 is standard on automatics, 3.5 is standard on the 6mt. 3.5 will help you accelerate faster on an n/a (and help you lose traction on a high hp turbo setup lol).
heres pretty much how its summed up; 3.5 gearing will get you faster acceleration but shorten the lenght of each gear, and overall top speed. 3.3 does the exact opposite, longer gearing, slightly slower acceleration.
if your planning on staying n/a go for the 3.5, if you intend on doing a high hp turbo setup, get the 3.3 (longer gearing) and helps with traction.
Old Dec 23, 2008 | 11:08 AM
bovi's Avatar
bovi
Thanks a lot bro, i stay N/A.
Old Dec 23, 2008 | 11:48 AM
ACEMAN's Avatar
ACEMAN
Master
Here is some info on the different final drives
https://my350z.com/forum/engine-and-drivetrain/301451-4-083-gears-final-drive-installed.html
Todd
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
