difference between 1.5 way lsd and 2 way lsd
Old Dec 28, 2008 | 08:19 AM
sillyme's Avatar
sillyme
Default difference between 1.5 way lsd and 2 way lsd
this is my daily driver and I do some road racing (twice a year). I'm looking for a lsd and decided on either Kaaz, Cusco, or Tomei. But I can't figure out which way should I get? I'm far from being a pro driver so I want something forgiving too. I read Kaaz website saying 2 way is recommended for RWD cars.
Old Dec 28, 2008 | 09:54 AM
JETPILOT's Avatar
JETPILOT
You should look into the OS Giken. It's probably the best differential out there. Only go 1.5 way for road racing. You don't want full lock up on decel.
Old Dec 28, 2008 | 11:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
In 1.5 way mode, the LSD activates under acceleration and is only partially engaged under deceleration. Understeer is less than on the 2 way LSD. Recommended for drivers having difficulty with 2 way LSD understeer, or for those doing street/road race driving.
The 2 way LSD activates on both acceleration and deceleration, making it desirable for drift use.
1. do you have a base model?
2. what tires are you running on the track?
3. what's your budget?
Old Dec 28, 2008 | 06:41 PM
sillyme's Avatar
sillyme
Default i got
base model
255/35/18 front 275/35/18 rear
7-$900 budget
is the Kaaz 1.5 way?
Old Dec 29, 2008 | 08:28 AM
Z1 Performance
Former Sponsor
NISMO one would be your best bet as everything needed for install to a base is included - not the smoothest diff out there, but certainly works well
Old Dec 29, 2008 | 09:09 AM
Escobar's Avatar
Escobar
Can't go wrong with a Cusco 1.5.
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
