Pumpkin Rear Diff Exploded • What went wrong?
Old Jan 12, 2009 | 07:31 AM
thom000001's Avatar
thom000001
Wow dodged a big bullet there. Get back to driving now
Old Jan 12, 2009 | 07:49 AM
__jb's Avatar
__jb
Z + Rear Seat
Hard to believe none of the gears were chipped. Did you actually look at the gears?
I wouldn't be too happy with a shop if one of the bolts fell out and broke through the diff cover.
Old Jan 12, 2009 | 07:55 AM
cheshirecat79's Avatar
cheshirecat79
Glad to hear they fixed the problem for you.
Old Jan 12, 2009 | 08:26 AM
Madbomber's Avatar
Madbomber
Adam from Z1 Performance said if anything is chipped or messed on the gears.. the rear would make a noticeable howling.. since i stopped immediately at the sound of grinding the lose bolt didnt have a chance to damage anything. even if a future problem arrises, Japtrix said they'd cover the costs involved.
Old Jan 12, 2009 | 08:42 AM
WhiskeyHotel's Avatar
WhiskeyHotel
Glad this worked out. (I'm still trying to figure out how they knew the bolts were torqued to spec if one was launched through the diff and the other was laying on the bottom. )
Old Jan 12, 2009 | 08:52 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Yep Roger and I spoke a couple times on Friday. Once before he had everything disassembled, and then once he put it all back together. Glad to see you dodged a bullet from the sounds of it, and that you're back on the road
Old Jan 12, 2009 | 08:54 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Good too hear, coulda been a lot worse
Old Jan 13, 2009 | 01:10 PM
gothchick's Avatar
gothchick
Glad it got fixed.... Pumpkins / gears ain't exactly cheap...
Old Jan 14, 2009 | 07:43 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by Madbomber
the Z was towed to Japtrix on friday. Roger (shop owner) called back later that afternoon with an update. a bolt had come loose and was flung through the rear diff cover causing the golf ball size hole. since the hole was towards the top, the oil had a chance to stay somewhat stay in the diff, meaning it was never run dry. that was the first zaboom.. and the second was the rest of the bolt getting caught on the LSD and rear cover. when he opened the drain plug almost a quart of oil was still left and one bolt came out with the cover removed. none of the gears were damage.. he cleaned everything up, placed a new cover on, and oiled up the diff. after 5k miles he wants the car back for a rear oil change. the car is giving no howling noise and driving great! Japtrix is a very reputable shop and this experience started a long term relationship with the shop. they covered everything and my only expense was the original tow from the street to my home of $100.
Sweet! Glad this had a happy ending...
Old Jan 17, 2009 | 07:55 PM
Berk_Technology's Avatar
Berk_Technology
Props to Japtrix!
Old Jan 17, 2009 | 08:13 PM
kramykram's Avatar
kramykram
the specific cause of the problem was no lock tight was used in assembly even though all bolt were torqued to spec.
hmmm i built mine and didn't use any locktite and im at over 15k miles with no problems. lol guess i need to drop it and check my torque on the bolts.
Obadabot
Jun 18, 2023 11:31 PM
