Going from Synthetic to Regular
Old Jan 20, 2009 | 01:03 PM
carlos305's Avatar
carlos305
Default Going from Synthetic to Regular
I was thinking about going from synthetic back to regular oil but i was reading that synthetic makes a bond on moving parts that doesn't blend with regular oil, is there anything i should use to flush out the sythetic oil before puting in the regular oil again?
Old Jan 20, 2009 | 01:19 PM
OrleanZ33's Avatar
OrleanZ33
That would be downgrading. Why would you want to switch from Synthetic to conventional oil ?
Old Jan 20, 2009 | 01:24 PM
jgregory124's Avatar
jgregory124
why are you switching?
Old Jan 20, 2009 | 01:30 PM
carlos305's Avatar
carlos305
its actually a friend of mine that wants to do the switch because his engine is burning oil so since regular oil is thicker he figured it will burn less
Old Jan 20, 2009 | 01:33 PM
Dsmashin's Avatar
Dsmashin
Hey guys i was wondering would it be worth it to switch from reg to synthetic. I have 42000 miles. Ive heard that with this many miles it wouldnt be worth it but the person me that talks too much and i cant tell when he is blowin smoke or tellin me the truth.
Old Jan 20, 2009 | 01:39 PM
quietkilla6's Avatar
quietkilla6
there is a oil cleaning addative that you put in run your engine for a like 10 mins then drain before you put in your new oil, but on old engines theres parts that are kinda held together by old oil. that could lead to blowing up your engine so id say just stick to synthetic.
Talk to a mec before trying this because i may be wrong, ive never used these products so this is just word of mouth.
Old Jan 20, 2009 | 02:30 PM
jgregory124
regular oil breaks down to quickly, synthetic is higher quality I would use any thing else I just switched over to Castrol Synthec......
Old Jan 20, 2009 | 03:05 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Old wifes tale as you can switch between synthetic and dino anytime you like.
Old Jan 20, 2009 | 04:44 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Silly question. Why doesn't your friend find out why the engine is burning oil? Viscosity rating tells your oil "thickness". Not whether it's synthetic or not.
Is it really burning oil, or just leaking? Does he have an '06 that might have the oil consumption issue?
Old Jan 20, 2009 | 08:57 PM
Better not. The motor will surely explode.
Old Jan 21, 2009 | 10:20 AM
carlos305's Avatar
carlos305
its not leaking its an 06 with oil consumption...
Old Jan 21, 2009 | 12:41 PM
terrasmak's Avatar
No difference, and you will still have the same amount of oil being burned.
Old Jan 21, 2009 | 12:43 PM
Jeff92se's Avatar
Jeff92se
Then leave the leaky oil in there and see a dealer about a replacement under warranty
Old Jan 21, 2009 | 03:04 PM
NISMO_558's Avatar
NISMO_558
he's probably just a cheap @ss and doesn't want to cough up the extra $ for the synthetic
Old Jan 21, 2009 | 03:34 PM
carlos305's Avatar
carlos305
whether or not he is a cheap *** is irrelevent to the question being asked...
Old Jan 21, 2009 | 03:35 PM
vnarang's Avatar
vnarang
any person that does that to their Z is nothing but a mere fool
Old Jan 21, 2009 | 07:48 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
ummm im no mechanic but im pretty sure u cant or what David said.....BOOM
Old Jan 21, 2009 | 07:53 PM
Nexx's Avatar
Nexx
+1
seagrasser
Oct 11, 2015 03:27 PM
Stevo Z
Oct 3, 2015 09:14 PM
AbyteZero
Sep 22, 2015 09:17 AM
