Speedometer stopped working! Help!
Old Jan 22, 2009 | 06:30 AM
specialized5223's Avatar
specialized5223
Default Speedometer stopped working! Help!
I ned an inspection today and this is going to make me fail.
I need some help quick. it worked. I disconnected the center consol gauge cluster above the radio and reconnected it, now it doesnt work. i rechecked it, everything is hooked up fine. still doesnt work.
I was thinking maybe this effected the odometer somehow so t needs to be dealer reset...
Old Jan 22, 2009 | 11:42 AM
gothchick's Avatar
gothchick
Check all connections again.
Old Jan 22, 2009 | 02:22 PM
specialized5223
did
checked the speed senors, then that wiring which goes up into the tonneau but then you cant see it all the way up to the ecu. disonnected the iggy back and reattatched it. reset the ecu numerous times.
its not a blown fuse because the gauges still have power going to them unless ther is a blown fuse for the speed sensors themselves.
i'm not good with plastic sit or electrical stuff so this has got me stumped like woah.
Old Jan 23, 2009 | 04:57 AM
gothchick's Avatar
gothchick
Take it to the dealership. They can plug in a Consult II and run diagnostics to see what you messed up...
Old Jan 23, 2009 | 07:42 AM
bbs350z's Avatar
bbs350z
id assume you checked every connection was indeed cinnected? if you continue to have problems, i have an extra cluster ill sell you for dirt cheap. pm me if your interested
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
