The "truth" about synthetic oil.
Old Feb 21, 2009 | 02:16 PM
Subninja's Avatar
Subninja
Default The "truth" about synthetic oil.
So I found this thread. It is pretty cool though the last post on the 1st page makes a lot of sense to. Doesn't change the dyno numbers though.
http://my.prostreetonline.com/t2540.htm
Old Feb 21, 2009 | 02:25 PM
Spork's Avatar
Spork
I don't believe it. Too many variable come into play IMO.
Reading the comments of people b*tching angered me. A guy with a Cavalier shouldn't be there.
Old Feb 21, 2009 | 02:41 PM
terrasmak's Avatar
work won't let me read it, would really love to.
Old Feb 21, 2009 | 03:22 PM
jray8's Avatar
jray8
engine bay=filthy
Old Feb 21, 2009 | 03:49 PM
RBZ33's Avatar
RBZ33
good info
Old Feb 21, 2009 | 05:00 PM
Sunset350Z's Avatar
Sunset350Z
interesting, not sure if I believe oil could make that much of a difference though
Old Feb 21, 2009 | 05:28 PM
foreveryoung's Avatar
foreveryoung
If one oil made more power than another,It would be widely public knowledge and the only oil every car maker and racer used.This test is bunk.
Old Feb 21, 2009 | 07:17 PM
Zian's Avatar
Zian
Interesting test, but yeah I agree the range for variance on a dyno is generally at least a few hp...more than enough to offset any "gains" from oils. Does make a pretty good case for using synthetic tho.
Old Feb 21, 2009 | 07:38 PM
Subninja's Avatar
Subninja
Well they did an independent dyno. The numbers are the numbers. Can't argue that point. And if you all think it is such a load of crap then you should be running mineral oil in your car instead of synthetic. All I am saying is these guys ran the same car with different oils and the power output changed based off of that. Make your own conclusions. I personally run Royal Purple and not because of this thread.
Old Feb 21, 2009 | 07:41 PM
michaeljr6's Avatar
michaeljr6
don't care what link says but 5000 oil change for synthetic and 3000 for regular.
Old Feb 21, 2009 | 07:48 PM
Steve-O Z33's Avatar
Steve-O Z33
I used to use RP but it seemed to be water thin when I changed it.
Old Feb 21, 2009 | 08:46 PM
2fast4comfort's Avatar
2fast4comfort
so they are saying oil can give you 17hp at the wheels. thats the biggest load of crap i have ever hear
Old Feb 21, 2009 | 11:22 PM
Nexx's Avatar
Nexx
thinner oils should produce a bit more power with less protection?
Old Feb 22, 2009 | 09:06 PM
Subninja's Avatar
Subninja
Not that I have any proof but I think I would prefer "thinner" oil when I changed it than oil that was thicker than when I originally put it in there. Seems like chance of getting buildup...but that is just me.
lapham3
Oct 7, 2022 03:15 PM
seagrasser
Oct 11, 2015 03:27 PM
Stevo Z
Oct 3, 2015 09:14 PM
