Need a lil INFO...
Old Sep 8, 2003 | 08:25 AM
infidsg35's Avatar
infidsg35
Default Need a lil INFO...
My Intake should be here any day now. When I install it what should I do as far as the ECU? Should I go with the reset? Leave it alone? Anyone have a procedure if there are any? Any help or advice or just plain ol FACTS would be great
Old Sep 8, 2003 | 08:36 AM
twenzel's Avatar
twenzel
reset it. I disconnected the battery to reset mine.
Old Sep 8, 2003 | 09:10 AM
infidsg35's Avatar
infidsg35
But witch is better a Reset or Battery disconnect? Plus doesnt it take the ECU a couple of days to learn the new air?
Old Sep 8, 2003 | 09:22 AM
jesseenglish's Avatar
jesseenglish
Originally posted by Mannishboy
It takes 24 hours according to the shop manual to reset the ECU if you just pull the battery.
You can also do it this way:
1) Make sure the ignition is switched off.
2) Wait at least 10 secs, then switch On (not started)
3) Wait 3 seconds
4) Press and release accelerator quickly 5 times within 5 seconds
5) Wait 7 seconds
6) Fully push and hold accelerator for 10 seconds until the MIL starts to blink
7) Release accelerator (you are in diagnostic mode)
8) To erase, press the accelerator fully and hold for at least 10 seconds
Old Sep 8, 2003 | 10:29 AM
xndsan's Avatar
xndsan
I just disconnected the battery when I did mine. Took about 3 hours with intake and exhaust. I thought that the ECU reset after 20 min with the battery disconnected.
Old Sep 8, 2003 | 10:35 AM
350zroadster's Avatar
350zroadster
solid state memory, it'll stay in there before you expire
SoCalKid86
Jul 24, 2003 11:20 PM
Acree
Jun 14, 2003 03:53 PM
jaxxxx
May 6, 2003 08:26 AM
LIL RAJA
Jan 19, 2003 07:39 AM
