help cusco strut bar and 5/16 spacer
Old Feb 24, 2009 | 02:47 PM
zero degrees's Avatar
zero degrees
Default help cusco strut bar and 5/16 spacer
i install a motordyne 5/16 spacer on my intake and also purchased a cusco strut bar. i just put the spacer on and am test fitting the strut bar and i have 1/4 inch between the strut bar and the intake manifold. is this sufficent or should i put the spacer on there???
Old Feb 24, 2009 | 03:21 PM
SuperBlack350z's Avatar
SuperBlack350z
you need to put some washers where the strut bar bolts go so it will lift the bar up for more clearance. I basically have the same set up as you.
Old Feb 24, 2009 | 04:29 PM
JMS71585's Avatar
JMS71585
So the cusco strut bar does not clear the 5/16 spacer? I installed a 5/16 spacer and was trying to find out whether the cusco clears it without spacers...
Old Feb 24, 2009 | 04:33 PM
SuperBlack350z
it does not clear the plenum unless you use those washers under the bolts of the strut bar. but it does fit if you do use them. just make sure you don't put too many washers or then the hood won't close.
Old Feb 24, 2009 | 04:46 PM
JMS71585's Avatar
JMS71585
Thanks man. i'm using the stock one with spacers, and was going to purchase the cusco one if it cleared without spacers, but i'll just stick with the stock one...
Old Feb 25, 2009 | 05:53 AM
zero degrees
yeah i put it on without the spacer and didn't check after finished and it is touching, so my just polished plentum and new strut bar have some scratches on them.
Old Feb 25, 2009 | 08:18 AM
vthao's Avatar
vthao
The cusco bar is nice, if you want it just get it and use your spacers.
Old Feb 25, 2009 | 04:30 PM
Tomci08's Avatar
Tomci08
my cusco rubbed my hood after installing the regular spacers that were supplied with the plenum spacer. Actually had to change them and once i did that it rubbed my plenum so i said screw it and tossed the strut bar.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
