friction free 3000 engine treatment?
Old Feb 25, 2009 | 05:13 AM
VQdriver's Avatar
VQdriver
Default friction free 3000 engine treatment?
so someone posted this on my facebook lol. of course i mentioned that nothing is better than a good synthetic oil (such as german castrol and pennzoil plat) or even castrol gtx used by themselves in proper service intervals. so has anyone here dared to try this? sounds like a good way to starve your motor of oil...but maybe i'm old fashioned lol. well the dude that posted to me is a chemical engineer..i guess that makes me a racecar driver =P
http://www.marketamerica.com/karijackson...
Company Overview:
Friction Free™ 3000 is an engine oil additive lubricant made of soft ductile metals, uniform and spherical in shape, ranging from 5 to 15 microns in size. These soft metals are coupled with special suspension agents to provide a solid boundary lubrication that can provide enhanced engine performance even under extreme conditions. Friction Free 3000 has been shown to provide superior engine lubrication, improve engine power, increase fuel economy, reduce emissions and reduce engine surface wear. And it's so easy! It only takes 15 seconds to add a bottle of Friction Free 3000 to your car's oil. Do this after each oil change for best results.
Americans today on average keep their automobiles seven years. Automobile and truck maintenance has become an American obsession, creating a need for advanced technology in car care. Maintaining high performance and engine efficiency has become a major concern since this area represents the most costly repairs when a breakdown occurs.
When two hard metal surfaces collide, conventional fluid film lubrication can fail. Friction forces generate tremendous heat, creating intense lubrication demands. Unfulfilled demand and inadequate lubrication can result in:
Poor engine performance
Lower compression
Increased oil consumption
Poor mileage
Dry starts
Increased engine wear and shorter engine life
A step beyond ordinary lubrication. Friction Free 3000 Engine Treatment protects and preserves new and old engines alike. Metallurgists in the field of tribology (the study of friction) confirm that soft metals provide superior friction-reducing quality and enhanced lubrication between two hard surfaces. The proper use of Friction Free 3000 can help increase gas mileage, prevent dry starts, and reduce exhaust emissions.
As metal moves against metal, microscopic soft-metal particles migrate into pits, crevices, and scratches caused by friction wear. Unlike conventional film lubricants, which cannot properly protect against these conditions, Friction Free 3000's micro-metals fill, pack and plate the imperfect surfaces. The remaining micro-metals constantly circulate to provide added lubrication while seeking out new areas of surface wear.
Friction Free 3000 is intended for use in gasoline engines and should be poured into the oil reservoir, NOT the fuel tank. It can be used in small 4-cycle engines, but should not be used in 2-cycle engines where oil is mixed directly with the fuel. Friction Free 3000 is compatible with both standard and synthetic motor oils. Instructions: Change the oil and filter or have the oil and filter changed by a qualified professional. Start the engine and allow it to reach regular operating temperature. Stop the engine and immediately add a complete bottle of Friction Free 3000 Engine Treatment to your engine's crankcase (where you add your engine oil). Immediately restart the engine and continue to drive the vehicle at normal speeds for at least ten minutes.
Transmissions and Gearboxes: Friction Free 3000 can be used for standard transmissions, differentials, and gearboxes, but is NOT intended for use in automatic transmissions, limited slip or positraction differentials, or any unit requiring limited lubrication.
Compressors and Hydraulic Systems: Friction Free 3000 may be used in hydraulic systems. Treatment ratio is 2 oz per gallon up to 5 gallons, then add 1/2 oz. per gallon thereafter. This product is NOT intended for use in high-pressure multi-state compressors over 500 psi. (read less)
Friction Free™ 3000 is an engine oil additive lubricant made of soft ductile metals, uniform and spherical in shape, ranging from 5 to 15 microns in size. These soft metals are coupled with special suspension agents to provide a solid boundary lubrication that can provide enhanced engine performance even under extreme conditions. Friction Free 3000 has been shown to provide superior engine lubrication, improve engine power, increase fuel economy, reduce emissions and reduce engine surface... (read more)
Mission:
Increases gas mileage
Prevents dry starts
Reduces oil consumption
Better engine performance
Normal compression
Decreased engine wear
Increases engine life
Products:
Friction Free 3000 Engine treatme
Old Feb 25, 2009 | 05:45 AM
Brrcats's Avatar
Brrcats
I'm a chemical engineer and I say its ********.
now what are you going to believe?
Old Feb 25, 2009 | 05:48 AM
cheshirecat79's Avatar
cheshirecat79
Please don't.
Old Feb 25, 2009 | 05:55 AM
VQdriver's Avatar
VQdriver
like i stated, it's GC and pennzoil plat ftgdmfw son!
Old Feb 25, 2009 | 06:09 AM
PerfZ's Avatar
PerfZ
Sounds like the old Slick 50 product from a few years back. Which I don't think is even sold any more. Nothing except OIL should go into the OIL.
Old Feb 25, 2009 | 06:13 AM
06blueZ's Avatar
06blueZ
snake oil...
Old Feb 25, 2009 | 05:56 PM
foreveryoung's Avatar
foreveryoung
I am not much of a fan of additives but I have an interesting story.Many years ago,back in the carburated 1970s,the shop I worked at used a GM product that was simply called Lubricity Additive.It was used to supply extra lube to the stock GM rocker arms with the ball deal the rocker pivoted on.Not a word of a lie,we would have a car on the scope monitoring idle speed,toss in this little can of additive and the idle would pick up 50 RPM .I have no slick explaination but it was always amazing to see.
liqalu04
Jan 2, 2022 12:58 PM
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
