Noise after engaging clutch*****it's not the chatter~
Old Mar 21, 2009 | 05:01 PM
OrthoDoc's Avatar
OrthoDoc
Default Noise after engaging clutch*****it's not the chatter~
I am hearing whinning like noise after I engage the clutch, but it goes away after disengage (stepping on the clutch). It's like the whinning sound that you get when you go in reverse.
I have changed transmission oil the pennzoil synchrommesh couple of days ago, and I didn't hear that right after I changed it.
Any idea what is causing this sound?
Old Mar 22, 2009 | 08:16 AM
ladyzed's Avatar
ladyzed
Check the fluid?
Old Mar 22, 2009 | 11:41 PM
OrthoDoc's Avatar
OrthoDoc
I have changed back to 75W-85, but I can still hear that whinning sound. I can hear them in all gear, and the sound goes away when I step on the clutch.
Old Mar 23, 2009 | 08:12 AM
350z 6spd's Avatar
350z 6spd
My trans did that so I brought it to the dealer and when I was talking to the tech he said it was the input shaft bearing. Although It could be any of the bearings or gears. They replaced the trans under warranty although I doubt they would do that judging by your sig lol. Nice setup btw.
Old Jun 15, 2010 | 09:00 AM
Wu-Watt's Avatar
Wu-Watt
My car is doing this... It's not a bearing or you would feel it. It's either the trans, or something to do with the clutch disk. At least I think on my car anyway. It only does it when the car is cold.
Old Jun 25, 2010 | 07:27 AM
jtmroczk's Avatar
jtmroczk
same issue, only when its cold, just filled with 75w90 about a week ago
Old Jun 25, 2010 | 08:09 AM
binder's Avatar
binder
umm, it most certainly CAN be a bearing. bearings will make noise way before they fail enough to vibrate.
bearings make a "whine" when they start to wear out. It progressively gets worse til it fails.
The issue is that with the car rolling and the clutch pressed in (car still in the gear it was making the noise) it will still make the noise if it was that bearing. It is based on the trans moving and not engagement of the clutch. So if you pull it up to 30mph in 2nd gear, hear the noise, push in the clutch and coast (while shifter still in 2nd gear) it should still make the noise since technically the trans will still be moving at that speed.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
