350Z for 3 Weeks....Oil Issues Already!
Old Apr 22, 2009 | 03:06 PM
eNdiT's Avatar
eNdiT
Default 350Z for 3 Weeks....Oil Issues Already!
Ok so in 3 weeks my oil is only halfway between the L and H line on th edipstick...that being said, the oil light is not on in the car. Should I be concerned yet? Also how many quarts of oil do I need to add if it is halfway to the "H" on the dipstick? Please help - worried new owner here.
Yes it's an '06 MT 6spd
Old Apr 22, 2009 | 03:19 PM
eNdiT's Avatar
eNdiT
OK I read the "Top 100 Questions" and learned alot...10W-30 and non-synthetic oil. So I guess I need to add approx 2 quarts if I'm halfway down?
Old Apr 22, 2009 | 03:37 PM
Exodus751's Avatar
Exodus751
actually from low to high on dipstick is about quart
and it is suppose to be in the middle of it
and it also depends when you check'em
try checking first thing in the morning when the oil's all on the pan it should read full
Old Apr 22, 2009 | 03:45 PM
Adding oil is a stopgap measure. It doesnt fix the problem. You may need to replace the motor.
Old Apr 22, 2009 | 03:57 PM
KS0385's Avatar
KS0385
^ If I was him and saw that.
Old Apr 22, 2009 | 03:58 PM
eNdiT's Avatar
eNdiT
I plan to read the entire "replace the motor" encyclopedia that you guys have so thoughtfully written over the years. However, can someone sum up how I go about doing this? Here's the background on the car:
1. Someone in ATL owned it
2. Carmax acquired it
3. I purchased it from Carmax
4. The car is a 2006 MT 6spd with 24K miles on it
How do I start this process to determine if it is necessary or not to replace the motor? I'd like to get some expert advice from actual Z owners here...I greatly value all of your insight.
Thanks in advance fellas!
Old Apr 22, 2009 | 04:13 PM
eNdiT's Avatar
eNdiT
I think I may be in the clear because I've been running the car hard for the last 2 weeks (enjoying the speed it was built for). If the oil line is supposed to be between the L and the H after resting for a few hours then I'm good to go. It's about 3/4ths up the way to the H line. I'll continue to monitor for the next couple of weeks.
Old Apr 22, 2009 | 04:26 PM
jray8's Avatar
jray8
2006=nuff said
Old Apr 22, 2009 | 04:32 PM
See if the problem persists.
Take the car to Nissan. They should do a consumption test.
Old Apr 22, 2009 | 04:35 PM
Waiz's Avatar
Waiz
Read this thread, and then do as davidv suggested.
https://my350z.com/forum/engine-and-...iscussion.html
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
Ronso
Oct 30, 2015 12:39 PM
issyz
Sep 12, 2015 04:18 PM
Darkspy
Sep 7, 2015 09:09 PM
