need help with p0430,p0420,p0300 CODES
Old May 5, 2009 | 01:40 PM
cg04350z's Avatar
cg04350z
Default need help with p0430,p0420,p0300 CODES
after installing headers and test pipes i got this codes and my ses light came on p0430,p0420,p0300. what can i do to correct them?
Old May 5, 2009 | 01:48 PM
cdoxp800's Avatar
cdoxp800
P0430
DTC Name
Catalyst System Efficiency Below Threshold
Bank 2
P0420
DTC Name
Bank 1
P0300
DTC Name
Random/Multiple Cylinder Misfire Detected
This should help you some.
You also may want to try to Search:
p0430 Search:
https://my350z.com/forum/search.php?searchid=8929412
P0420 Search:
https://my350z.com/forum/search.php?searchid=8929421
p0300 Search:
https://my350z.com/forum/search.php?searchid=8929427
Old May 5, 2009 | 02:17 PM
singh's Avatar
singh
_______________
the one you should be concerned about is the p0300 misfire CEL.
The p0420/p0430 are coming from your test pipes. Use nonfoulers to place the O2 sensors further away from the exhaust stream.
Old May 5, 2009 | 02:56 PM
cg04350z's Avatar
cg04350z
thanx man were can i buy that and price?
Old May 5, 2009 | 03:01 PM
BrazenZ's Avatar
BrazenZ
Wow, no flaming? This is refreshing change from the usual noob treatment.
Old May 5, 2009 | 04:51 PM
singh's Avatar
singh
_______________
There's a guy on here username: Zexy
He makes them and I think he sells them for like $20.
Old May 6, 2009 | 01:23 PM
rcdash's Avatar
rcdash
check for exhaust leaks also...
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
