Installation questions
Old Sep 21, 2003 | 05:28 PM
JPizzle's Avatar
JPizzle
Default Installation questions
How easy and time consuming will it be to install my borla td, jwt popcharger, and earth grounding kit?
Old Sep 21, 2003 | 06:19 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I did my InsameAmine grounding kit in about 45 minutes.
I did my AEM intake in about 2 hours and it is a lot more involved than the Pop Charger so maybe you could do it in an hour or so.
My Borla was installed by a local muffler shop in about 90 minutes and it cost me about $90.00.
Old Sep 21, 2003 | 06:23 PM
JPizzle's Avatar
JPizzle
did you have your exhaust clamped or welded?
Old Sep 21, 2003 | 06:26 PM
MY350Z.COM's Avatar
Only piece that really needs welding is the H-pipe junction.
Old Sep 21, 2003 | 06:28 PM
JPizzle's Avatar
JPizzle
well, if you're excessive compulsive (like we all know doc is ) you can have it all welded just to be safe
Old Sep 21, 2003 | 06:32 PM
MY350Z.COM's Avatar
Yeah, I considered that, but if you ever need to take it off. You gotta bring it back to the shop. I'll get the others welded if they leak, otherwise I think they should be just fine.
Old Sep 21, 2003 | 08:20 PM
Wedge's Avatar
Wedge
So the H pipe should be welded? Is that the common thing to do?
Do the majority of Borla owners have it welded? Just asking because I am going to install mine tomorrow.
Thanks
Old Sep 21, 2003 | 08:21 PM
JPizzle's Avatar
JPizzle
wedge, let me know how the installation goes, from what I had read, I was under the presumption that I could just clamp everything.
Old Sep 21, 2003 | 08:42 PM
Wedge's Avatar
Wedge
Default JWT Pop Charger
The hardest thing about installing the pop charger is marking and drilling the two holes in the existing air duct for the heat shield bracket.
You will get black and white instructions with the pop charger, but if you want to see some clearer color pictures, go here:
http://www.courtesyparts.com/instruct/Z3303-JWT.html
The bottom of the heat shield just clamps onto a ridge (you will see this in the color instructions), the bracket of the heat shield is screwed to the existing plastic air duct.
The air duct will not come out (for easy marking and drilling) without removing the front bumper which I really did not want to do. So I clamped the heat shield in place with the heat shield bracket on the INSIDE of the plastic air duct. I did this in order to mark the position of the holes to be drilled in the air duct. I then loosened the clamp holding the heat shield and removed the heat shield. Then I drilled the holes in the plastic air duct (from the inside out), reclamped the heat shield in place with the heat shield bracket on the OUTSIDE of the air duct and used the two short phillips head sheet metal screws (supplied) to fasten the air duct to the heat shield. You will need a short stubby phillips head screw driver to accomplish this.
You should be able to get the whole thing done in an hour or so......maybe less.
Old Sep 21, 2003 | 08:44 PM
Wedge's Avatar
Wedge
Default JPizzle....
Will do JPizzle........I will give you a full report
Old Sep 21, 2003 | 10:40 PM
jesseenglish's Avatar
jesseenglish
I didn't weld my H-pipe and it works great. It took me about 1 hour to install the kit with the help of a friend and using a lift.
Old Sep 21, 2003 | 10:42 PM
JPizzle's Avatar
JPizzle
Yeah, from what I heard the lift shaves a good hour of installation time, it's good to know that yours performs perfect without the welding, as that would save time and money.
Old Sep 21, 2003 | 10:47 PM
jesseenglish
Just make sure the two ends are seated well together and clamp that **** down, it'll be fine.
Old Sep 21, 2003 | 11:44 PM
Wedge's Avatar
Wedge
Thanks for tips jesseenglish.........I will indeed clamp that **** down.........
Old Sep 22, 2003 | 01:05 AM
raceboy's Avatar
raceboy
Just clamp it. If you only knew how hard it is to get them back apart, you would never worry about welding it.
Old Sep 22, 2003 | 03:39 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Mine is NOT welded either. No problems.
Old Sep 22, 2003 | 06:00 AM
fowlman01's Avatar
fowlman01
no welds on my borla system and it hasn't leaked.
Old Sep 22, 2003 | 07:14 AM
Wedge's Avatar
Wedge
Thanks everyone........I feel better about just clamping the H pipe now.....
Old Sep 22, 2003 | 09:16 PM
Wedge's Avatar
Wedge
Default Borla Install went Just Fine....
I removed my stock exhaust and installed the Borla with no major problems at all. The rubber hangers are pretty tough to get off the old system, but some lube helped out a lot . There was one tough nut on one of the cats, but that was it.......after that everything went smoothly.
I will drive it for a while then double check all the connections. During my test following installation, there were no leaks at all using clamps only.
I did notice that my tips are about 1/4 inch shifted to the left .....so i will adjust that tomorrow.
The infamous look alike cat pipes are hard to tell apart as everyone said. The flanges are marked in hand written ink as "A" and "B". "B" was the drivers side and "A" was the passenger side of the car. This may save you some trouble if you are going to do a Borla install soon.
Wedge
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
