wont start. HELP
Old May 21, 2009 | 11:36 AM
SnyzzleZ's Avatar
SnyzzleZ
Default wont start. HELP
Im a new Z owner. And I really dont have the time to search the forums for an answer. Ive had the car for about 3 weeks.. it has 20k miles 03 track model. Only mods are a JWT intake and nismo exhaust and clifford alarm. Havnt had a SINGLE preoblem since i bought it. Everything has been perfect. Then I went to start it today and it would just crank and couldnt get it to start.. ???
Old May 21, 2009 | 08:50 PM
SnyzzleZ's Avatar
SnyzzleZ
bump
Old May 21, 2009 | 09:23 PM
SnyzzleZ's Avatar
SnyzzleZ
i read somewhere the keys may cause the problem. Ive been usin the same key since ive bought the car though.. Is there a chance something could have happend with it and the computer needs reset?
Old May 21, 2009 | 09:40 PM
mclovin.too's Avatar
mclovin.too
Is the battery dead? Is it trying to crank? All accessories work? Whats the voltmeter say when key is in the on position? I also bet that the alarm has a kill switch on it. Not saying that is the problem though.
Old May 21, 2009 | 10:00 PM
SnyzzleZ's Avatar
SnyzzleZ
battery is good.. it cranks fine.. tried about 20 times for it to start.. just keeps crankin
Old May 22, 2009 | 06:33 AM
Xlr82x's Avatar
Xlr82x
Is the alarm light a solid red and not blinking?
Old May 22, 2009 | 07:23 AM
mclovin.too
Throwing any codes?
Old May 22, 2009 | 09:26 AM
klaze1's Avatar
klaze1
did you check the flux capacitor? /thread
Old May 22, 2009 | 09:28 AM
magicballer2001's Avatar
magicballer2001
Mine has the same problem, it does it like once a week, it usually starts after 5 or so tries
mines an 03 with 33k miles
Old May 22, 2009 | 11:06 AM
bdavids1's Avatar
bdavids1
How did you determine that the battery is good? Load test? Since the car is an 03, there's a good chance the battery needs to be replaced. I have an 04, and had to replace the battery late last year. It showed that it was charged (i.e. correct voltage), but it couldn't supply enough current to get the car started.
Have you tried jump starting the car? If that works, it's almost certainly the battery.
Old May 22, 2009 | 06:08 PM
SnyzzleZ's Avatar
SnyzzleZ
ive checked everything I thought it could be.. so i had it towed to a local shop this morning, the guy there also couldnt figure it out..
determined the battery was good because it had the correct voltage and it will crank for hours if i let it ( seems like its gettin plenty of juice).. I tried probably 25 times to start it before i gave up.
Old May 22, 2009 | 07:43 PM
cheshirecat79's Avatar
cheshirecat79
Doesn't sound like it's the battery at this point. Check to see if the engine is getting fuel.
Old May 24, 2009 | 12:43 PM
magicballer2001
snyzzle keep this thread updated please, i have the same problem....just occurs once a week
Old May 24, 2009 | 04:25 PM
SnyzzleZ's Avatar
SnyzzleZ
will do man.
Old May 25, 2009 | 05:29 AM
Z04's Avatar
Z04
2003 had issues with the crank position sensor. this could cause the car to cut out or not start.
Old May 26, 2009 | 08:35 AM
SnyzzleZ's Avatar
SnyzzleZ
said it was the fuel pump.. my geuss (magicballer) if ur having trouble with it starting, yours is starting to go bad also.. Ive had a fuel pump go bad on one of my other cars before.. But this is the first time Ive had one that just suddenly wouldnt start.
Old May 26, 2009 | 10:06 AM
magicballer2001
ok well, if you get it replaced, and it fixes everything...let me know!
Old May 28, 2009 | 02:08 PM
SnyzzleZ's Avatar
SnyzzleZ
just got it replaced.. runs perfect!! bad thing is that the feul pump cost $350 plus labor.. of course the $350 was dealership prices so I would ask around, Im sure you can find it much cheaper.
Dr.Paulyy
Jul 29, 2019 07:45 AM
3vilbunny
Jul 18, 2017 05:10 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
05UltraYellow
Sep 24, 2015 05:41 AM
