Transmission friction/drag
Old Jun 1, 2009 | 04:48 PM
DavesZ#3's Avatar
DavesZ#3
Default Transmission friction/drag
Last week, I had the Z up on jackstands. I started it with the transmission in neutral and let the clutch out when I got out the car. I was surprised to see the rear wheels turning since I was in neutral. They weren't turning slow either, they were spinning like I would expect them to do if the car was in gear at idle.
As background - 45K miles on the trans. Trans oil changed to Royal Purple back around 25K miles. No other problems with it such as grinding, etc. It IS hard to shift 1-2, 2-3 when extremely cold.
Is there really that much drag on the internals? Any other explanation?
Old Jun 1, 2009 | 05:01 PM
usa_alex's Avatar
usa_alex
did you change the position of the clutch pedal?
Old Jun 1, 2009 | 05:12 PM
DavesZ#3's Avatar
DavesZ#3
I know where you're heading but read my post again. This is not the case of pressing the clutch in and having it not fully dis-engage, it's the opposite. The clutch was out, it was fully engaged and turning the flywheel and input shaft. I'm trying to figure out why the drive shaft was turning -- the car was in neutral, no gears.
Old Jun 1, 2009 | 05:20 PM
usa_alex's Avatar
usa_alex
got it my bad
Old Jun 1, 2009 | 05:22 PM
usa_alex's Avatar
usa_alex
did you noticed this after driving or on a cold start?
Old Jun 1, 2009 | 05:23 PM
usa_alex's Avatar
usa_alex
i have an 09/06 with 18k miles on it i'll try that in a day or two just for the heck of it maybe mine does the same ??
Old Jun 1, 2009 | 05:24 PM
DavesZ#3's Avatar
DavesZ#3
The car had been sitting for a while. I had been doing a brake job on it so it probably hadn't driven in about 2 hours.
Old Jun 1, 2009 | 05:26 PM
usa_alex's Avatar
usa_alex
i was thinking about the oil being cold but doesn't get cold in 2 hrs
Old Jun 1, 2009 | 05:34 PM
usa_alex's Avatar
usa_alex
know that you reminded me about the transmission i have a question
when i start my car (cold start) the rpm are 1k-1.2k and when i let the clutch go it goes down a bit
have any idea? sounds about the same thing with the thing you mentioned
Old Jun 1, 2009 | 05:40 PM
DavesZ#3's Avatar
DavesZ#3
When you first start it (cold), there are several idle enrichments that keep it higher than normal and richer than normal. Otherwise, you will always see a small drop as you let out the clutch and a bounce in RPM when you depress it. You have the extra weight and load of the clutch and input shaft when it's engaged so that would slow the engine slightly.
Old Jun 1, 2009 | 05:44 PM
usa_alex's Avatar
usa_alex
aha but what should be the rpm at cold and warm?
Old Jun 1, 2009 | 06:10 PM
DavesZ#3's Avatar
DavesZ#3
IDK - I'll have to try and pay attention tomorrow morning.
Old Jun 1, 2009 | 06:21 PM
usa_alex's Avatar
usa_alex
thanks
Old Jun 1, 2009 | 06:33 PM
usa_alex's Avatar
usa_alex
i'll do the thing tomorrow and i'll let you know if mine does the same or not
Old Jun 1, 2009 | 07:49 PM
zettahertz's Avatar
zettahertz
hmm, i just did that a few days ago, on jack stands on neutral but my wheels don't turn.
Old Jun 1, 2009 | 08:16 PM
Not sure how you can turn the rear wheels with the transmission in neutral. Common sense tells you that the transmission must NOT be in neutral.
Old Jun 2, 2009 | 03:20 AM
DavesZ#3's Avatar
DavesZ#3
That's why I'm asking. I KNOW that they shouldn't be turning.
Old Jun 2, 2009 | 03:22 AM
DavesZ#3's Avatar
DavesZ#3
Here's ya go ---
cold idle with clutch in 1500 rpm, clutch out 1400
hot idle with clutch in or out, 800.
I'd expect some drag when the trans is not up to operating temp but I'm surprised it's that much. I wonder if there's really that much drag to be able to turn the driveshaft.
Old Jun 9, 2009 | 09:29 PM
kaizenro1's Avatar
kaizenro1
My car (06 Track) doesn't have much take off from 1st. It's so hard to learn my clutch and gas pedal technique and I've had the car since Feb 28th.
Any advice?
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
