2007 HR Transmission in a 2003?
Old Jun 3, 2009 | 12:37 PM
Pepperinyoureye's Avatar
Pepperinyoureye
Exclamation 2007 HR Transmission in a 2003?
I searched quite a bit and found only one thread that talked about the question and the thread never got an answer.
I am looking into getting a Z and really wanted a 2005 and up but came across one in locally for sale which was an 03. Main reason I was not interested in the 03-04 was because of the weak factory synchros and the window motor issues.
I called the owner to come take a look at the car and he told me the transmission was replaced as well as the clutch with a 2007 Nismo transmission and Nismo clutch after he had a second gear grind. He showed me a work order from the Nissan dealer showing the replacement of the transmission.
From the test drive I could deffinately tell a difference in the clutch (compared to another Z I test drove last week) but I was really curious about the 2007 Transmission in an 03 and if that is even possible.
After doing some research I found that the Nismo uses the same transmission as a normal HR Z. I know the transmission is different from 07- but I really want to know if they are compatible or if the dealer told him it was an 07 tranny and really something else.
Thanks
Old Jun 3, 2009 | 01:58 PM
ssgohan434's Avatar
ssgohan434
When you say Nismo transmission, are you talking about a transmission from the Nismo edition 350Z? or a as in Nismo S-tune/R-tune Transmission? Cuz the later is not made.
The transmission is compatible with all years, it was revised throughout the years though.
Old Jun 3, 2009 | 03:09 PM
Pepperinyoureye
He said "2007 Nismo Transmission" I'm pretty sure its just the trans that comes in the 2007 Nismo but I thought the US spec Nismo used the same transmission as any other manual 2007 Z?
Old Aug 12, 2009 | 06:17 PM
Ibrown51484's Avatar
Ibrown51484
will it fitt!!!!
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
