CD0 009 tranny question (help)
Old Mar 31, 2009 | 03:35 PM
SuperBlack350z's Avatar
SuperBlack350z
Default CD0 009 tranny question (help)
so i'm talking to a guy locally that says he has a tranny out of an 07 Z. It's been rolled over and he salvaged this tranny.
On the tranny it says CD0 #5. Is something wrong here?
He said had to come from a newer HR motor because something on the tranny is hydraulic? Does anyone know what he is talking about and can confirm?
Old Mar 31, 2009 | 03:55 PM
SuperBlack350z
bump , need some help quick
Old Mar 31, 2009 | 04:07 PM
350z 6spd's Avatar
350z 6spd
Not sure about the cdo #5 (i think that is different prob stamped on the housing) but the hr utilizes a slave cylinder that is on the input shaft instead of being mounted outside of the transmission and using a clutch fork. In short, it sounds like it's from an 07 and should be a 009 but may not be. Is the cdo #5 stamped on the tranny or is it a sticker? If it is stamped then that is not the same as a sticker that says CD009, which is what you would go by.
Old Mar 31, 2009 | 04:19 PM
SuperBlack350z
Thanks for your input. it helped me out greatly. I feel better about you talking about the slave cylinder. Can it still work on previous years?
i'm pretty sure it's stamped/imprinted on the tranny itself. He described, it only says CD #5 and nothing else.
i looked at some tranny pics on the internet (not from him) and found this so maybe that's what he was talking about.
Old Mar 31, 2009 | 04:20 PM
twitch579's Avatar
twitch579
Its the wrong transmission. Look for another one.
Old Mar 31, 2009 | 04:28 PM
SuperBlack350z
the weird thing is, my tranny says cd #1. The pic shown was from an 06 350z shown here https://my350z.com/forum/drivetrain/...10k-clean.html
is there any other way to tell besides that little white sticker? He gave me a bunch of other numbers but i'm not sure what they are. All i know that there wasn't any 009 in them.
Old Mar 31, 2009 | 04:31 PM
350z 6spd's Avatar
350z 6spd
Not sure if the tranny's are interchangeable but regardless I think you have an older one (not CD009). I'm pretty sure the 009s have CD0 #2 stamped on them not CD0 #1 but I'll let someone else chime in.
Old Mar 31, 2009 | 04:39 PM
twitch579's Avatar
twitch579
My 04.5 came with a Cd008 and it grinded 3rd 4th and 5th horribly.
Now my 009 grinds 6th Real nice all the time. I have 35k on it.
Old Mar 31, 2009 | 04:43 PM
SuperBlack350z
^^ do you know what number was imprinted on your tranny? Not that little white sticker, like the pic i posted. thanks for the help guys. keep it coming.
Old Mar 31, 2009 | 07:42 PM
SuperBlack350z
bump
Old Mar 31, 2009 | 09:57 PM
SuperBlack350z
where are my smart Z people at?
Old Mar 31, 2009 | 10:14 PM
mthreat's Avatar
mthreat
I know the 2009's use a different tranny.
I *think* the 2007-2008 (HR) uses a different tranny than 2003-2006.
The best way I know to find out for sure is call your local Nissan parts dept and ask them if the tranny is the same for 2006 and 2007 models.
Old Apr 1, 2009 | 11:38 AM
Resolute's Avatar
Resolute
If this transmission came off the back of an VQ35HR, then it is not the same as the 005 tranny that Nissan was experimenting with on their way to the final 009 design for 03-06 VQ35DE engines. Chances are, the stamping on the bell housing is a different designation than the little sticker Nissan used on the early transmissions to distinguish their revisions.
That being said, I don't know if the DE and HR transmissions are interchangeable. The engine blocks are different, so the bell housing on the tranny's might not share the same size and pattern between them. I know the HR sits about 3/4" lower in the engine bay than the DE (to help compensate for the taller deck height), and this might have necessitated a change in the lower portion of the HR transmission's bell housing, and perhaps the transmission mount also? Hell, are the transmissions even the same length and do they use the exact same drive shaft? I don't know, but maybe a call to your local Nissan parts/service center would help. I think GTM is trying to swap a HR into an earlier Z33 chassis in place of the DE, they might know from looking at the two assemblies if the transmissions are interchangeable.
If they are interchangeable, then some plumbing work will need to be done since the slave cylinder is mounted inside the housing on the HR transmission.
Will (hopes they are interchangeable, and if so, would like to find a used one of his own)
edit: are the clutches compatible between the DE and HR engines? Another thing worth checking out.
Old Apr 2, 2009 | 10:51 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Andrew, I tried to look for your answer, but had no luck here.
You might wanna call performance nisssan and ask them.
http://www.trademotion.com/partlocat...?siteid=214252
chefj
Old Apr 2, 2009 | 03:56 PM
SuperBlack350z
thanks guys for your help. GTM and Forged Perfomance have confirmed that 2007 + transmissions won't work with previous years.
Old Apr 2, 2009 | 07:58 PM
bbs350z's Avatar
bbs350z
^^sure wont. get a cd009, not too expensive, and way better than our shitty 008
Old Apr 2, 2009 | 08:13 PM
twitch579's Avatar
twitch579
I know im not a smart Z person but I tried to tell u that already. It wont work. Different engine and transmission.
Old Apr 2, 2009 | 08:19 PM
SuperBlack350z
^^thanks for your help. i wanted to be sure.
Old Aug 12, 2009 | 06:28 PM
Ibrown51484's Avatar
Ibrown51484
A nissan tech told me he thinks you can swap the 07's casing with the 03' to make it fitt..i found a 07 for dirt cheap want to try it!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
