What can I do with this engine?
Old Sep 30, 2003 | 06:07 AM
ravaz's Avatar
ravaz
The fx35 only has 280hp at the crank, the fx45 is the one with more horse, but that's only 315 at the crank.
Old Sep 30, 2003 | 06:09 AM
Rxramon's Avatar
Rxramon
Charter Member #45
ok thanks...thinking 45
Old Sep 30, 2003 | 06:10 AM
Zship's Avatar
Zship
That is the FX45 4.5L V8 with 315HP. The FX35 with 3.5L makes 280HP.
Old Sep 30, 2003 | 06:15 AM
Iezzi's Avatar
Iezzi
rxramon your thinking of the FX45 a 4.5L V8. The FX35 has our VQ35DE and in the FX it produces 280hp.
Old Sep 30, 2003 | 06:16 AM
Iezzi's Avatar
Iezzi
Zship you beat me
Old Sep 30, 2003 | 06:21 AM
Rxramon's Avatar
Rxramon
Charter Member #45
4.5 only puts down 315 at the crank,
Thats about 267 at the wheels and if we all wheel drive the Z, throw in a rally suspension move the intake duct to a scoop position...... Were talking rally winner.
Now all we need is for crush to keep the parts
Old Sep 30, 2003 | 06:31 AM
nickyfngrs's Avatar
nickyfngrs
Default 350z LSD
do you happen to have any limited slip differentials from a 350z, or do you know where i may get one.
Old Sep 30, 2003 | 06:52 AM
peptidbond's Avatar
peptidbond
First, do a lot of investigation to verifry that the engines are identical. They may share the same block (crank, pistons, rods, etc.), but they may have vastly different plenums, heads, etc. This kind of stuff could really confuse the Z's ECU.
If that are the identical, I say you start moding the crap out of it. Start with a turbo and see what the stock internals can take. Remember, this engine is just for experimenting. Find the breaking point. Then but your original Z engine back in with the turbo setup, rods, pistons, brass value guides, titanium retainers and springs, etc. Then you can start to slowly tune and raise the boost even further. You just might end up with one beast of an engine.
Boring and stroking might be an option if you want to stay NA. However, a blueprint, balance and bore can only be partly transferred to a different engine.
Old Sep 30, 2003 | 06:02 PM
guerojo's Avatar
guerojo
Now your talking. As far as the engine its all the same. According to my interchange computer they are all the same. Z, G35 coupe and the FX are exactly the same. I have checked numbers and the looks of every mount and bolt and its exactly the same except for the cover.
On an another note.... 4 wheel drive Z hmmmmm thats a thought.
Old Sep 30, 2003 | 06:03 PM
guerojo's Avatar
guerojo
Default Re: 350z LSD
nope, and you might try car-part.com. Theres one guy with a z engine, he might have other things also.
Old Sep 30, 2003 | 06:14 PM
kurt leonce's Avatar
kurt leonce
how many engines did you get, i find it hard to belive you only got one engine out of all those cars someones hold back some info.
but I'm happy that you at lest got one out of it.
NOW LET THE MODING START
Old Sep 30, 2003 | 06:30 PM
guerojo's Avatar
guerojo
I got 18 Murano engines, which are the same as the Altima 3.5 and the Maximas 2002 and 2003. 2 Pathfinders and the one FX35. I figured nobody cared about the others.
Old Oct 1, 2003 | 07:43 AM
etx's Avatar
etx
My local engine builder said the VQ motors use sleved clys like honda blocks. He said if he wanted to keep the motor running for any legnth of time he would not boost it! I say you should prove him wrong!
Stroke the motor and throw in some 8.8:1 CP pistons w/ pauter or crower rods and some super agressive custom cams from crane. Then boost the motor to like 16 psi and be happy in 500 hp land! I don't know if anyone has installed low comp pistons in the vq35 yet for a boosted application, but the high comp rate of the stock internals is probably holding people back. May as well take your time and build a proper motor while its out of the car. What do you have to loose? Its a free motor! Boost it!
Old Oct 1, 2003 | 05:53 PM
guerojo's Avatar
guerojo
OK. Next question. Who could do something like that? I dont want to blow 10k on a free motor. That kinda defeats the purpose I think. I have a good mechanic that can build the hell out of a 350 chevy but to mess with this beast its a whole different story.
Old Oct 1, 2003 | 08:47 PM
Judge's Avatar
Judge
You wouldn't be 'blowing' 10K on a free motor.. you would be blowing a 'free' motor. Then use what you learn by 'blowing up' a free motor to learn what you can do to your motor. Just take the 10K in parts you bought and put them on your original motor.
Actually, if I had your opportunity, I would go all NA. Buy all the stronger internals you would use in a FI setup and go way aggressive the NA route. Stroke it or whatever else you can do to it. Then if you still want more, FI your original motor and keep the NA for a backup. If you blow your FI motor then crush that one and call it even.
Old Oct 1, 2003 | 09:00 PM
FLY BY Z's Avatar
FLY BY Z
What I want is a FX45 V8 to stuff into the Z. Let me know if you come across one of those, k?
Old Oct 2, 2003 | 07:35 PM
guerojo's Avatar
guerojo
When I get it I'll let you know how it looks in MY Z.
Old Oct 2, 2003 | 07:39 PM
  #38
alex30327's Avatar
alex30327
Would you be willing to sell any of these engines for parts?
Old Oct 4, 2003 | 02:23 PM
  #39
FLY BY Z's Avatar
FLY BY Z
Damn you!!!
Old Oct 4, 2003 | 06:23 PM
  #40
guerojo's Avatar
guerojo
Damn you!!!
lol
