2006 G35x Donor Engine for a 2003 350z
Old Jul 2, 2009 | 10:23 PM
MR RIZK's Avatar
MR RIZK
Default 2006 G35x Donor Engine for a 2003 350z
Guys need some feedback please.
I have located a donor 2006 G35x engine and was wondering if I was going to run into any issues transplanting this into my 2003 350z. I have been told that this is a non revup which is the same as mine.
I would assume that my existing loom will be ok with this motor. Im looking to do a direct drop in after the build and trying to reduce any complications that may occur.
Basically I will be using this motor to start my built motor project
Old Jul 3, 2009 | 05:17 AM
s.mckenzie82's Avatar
s.mckenzie82
As long as its a VQ35DE you should be stright. Correct me if I'm wrong guys, the only difference between these two motors is the drivetrain.
Old Jul 3, 2009 | 05:31 AM
JasonZ-YA's Avatar
JasonZ-YA
to my understanding yes, so he should be good...
ooooOOHH, do you just have engine? i would love to do an AWD Z just for the fun of the build..
-J
Old Jul 3, 2009 | 06:41 AM
YoungBB's Avatar
YoungBB
^^^interesting would like to see that
Old Jul 3, 2009 | 07:39 AM
JasonZ-YA's Avatar
JasonZ-YA
There are pics of it done already..........search around you should find it..
Old Jul 3, 2009 | 10:48 PM
MR RIZK's Avatar
MR RIZK
Just the engine. AWD would be awesome but i'm looking just to do a straight forward build for my HKS ST.
I was a bit concerned as i assume it was from a AWD model hence th G35x and was seeking advice on how similar the engines are.
michael
Old Jul 4, 2009 | 04:11 AM
Ilike350Z's Avatar
Ilike350Z
Old Jul 4, 2009 | 12:11 PM
s.mckenzie82
Dave has some sick nasty looking cars at his shop. My first 10-15 min there is usually spent looking at the monsters he has there.
Old Jul 4, 2009 | 01:53 PM
bbs350z's Avatar
bbs350z
you sure the 06 doesnt use a rev-up? then again being the x, not sure on that. if it is a rev-up motor you will also need the ecu, and wiring harness (you can tell if theres 4 cam sensors in the back, and 2 sensors below the cam covers)
Old Jul 4, 2009 | 02:45 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
I was thinking the same thing
Old Jul 4, 2009 | 04:45 PM
MR RIZK's Avatar
MR RIZK
I checked the 06 G35 FSM and can see that this has 4 sensors on the rear. I haven't managed to find the G35x FSM to compare.
Any one got linky linky
Will see if I can get some pics of the engine
Also I assume that I can swap out my upper oil pan to replace the G35x upper oil pan/transfer case
nissan1310
Oct 12, 2015 08:54 AM
foxsmp26
Sep 25, 2015 09:48 AM
hardkicks
Sep 20, 2015 12:28 PM
RWDBajan
Sep 8, 2015 06:25 AM
