Compression Test
Old Jul 15, 2009 | 10:30 PM
tohSeRuS's Avatar
tohSeRuS
Default Compression Test
I took my car in today to see how my compression was.
at WOT
1. 223
2. 225
3. 224
4. 222
5. 224
6. 225
Is this good?
They told me 142-185 at 300 rpm was good. but then why did they do it at WOT???
Old Jul 16, 2009 | 04:55 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Well first off there is no WOT for a compression test as all the plugs are removed and the engine is just spun by the starter.Whoever did the test are morons saying it was at WOT.
Old Jul 16, 2009 | 06:36 AM
vthao's Avatar
vthao
LOL, have you ever done a compression test before? WOT is used to open the throttle body so that air can be sucked into the motor, thus it having compression. Anyway, your numbers look fine, and compression tests are always done at WOT.
Old Jul 16, 2009 | 06:55 AM
superchargedg
Damn Noobs
Done tons of them but it just the way its worded that seems funny to me.300rpms and at WOT.....just seems like the shop or he didnt know the difference
Old Jul 16, 2009 | 08:42 AM
tohSeRuS's Avatar
tohSeRuS
thanks for the input. i was very confused with there information
Old Jul 16, 2009 | 02:45 PM
TheFarmer's Avatar
TheFarmer
According to Nissan, stock VQ30DE 185psi is the norm; 142 is the minimum with a maximum variance of 14 psi per cylinder. Don't worry about the WOT thing. Compression tests are usually done with the throttle wide open.
Don't know why your numbers are so high though, how many times did they crank it per cylinder? Did they do a wet compression test?
What year is your Z? Do you have the HR motor?
Old Jul 16, 2009 | 04:26 PM
1cockyZ's Avatar
1cockyZ
The lowest I saw on my built motor was 175 but i did it cold. 96mm 11:1 wisecos.
Old Jul 16, 2009 | 09:47 PM
tohSeRuS's Avatar
tohSeRuS
I have an 05 DE. they said my numbers were good tho?
Old Jul 20, 2009 | 03:00 PM
superchargedg
Damn Noobs
^^ we have a spammer and its been reported.
Old Jul 20, 2009 | 07:49 PM
tohSeRuS's Avatar
tohSeRuS
what are you talking about?
Old Jul 21, 2009 | 08:00 AM
djamps's Avatar
djamps
Those numbers are way high. Something isn't right.
Old Jul 21, 2009 | 02:52 PM
superchargedg
Damn Noobs
Not you as it was right after your post and i notified a moderator that someone spammed your post and that person is now gone.
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
