Which motor do I have?
Old Jul 25, 2009 | 08:11 AM
christian_wlcp's Avatar
christian_wlcp
Default Which motor do I have?
Sorry to be asking this but I've done some research and also called the local nissan dealership(did not know.. pretty ridiculous) and I still cant find my answer..
I've got a 2006 MT 350z.. motor VQ35DE.
Maybe I've read too much into some of the different motor information but I was under the impression that there is the VQ35DE NON REV-UP, VQ35DE REV-UP, and the VQ35HR(new to 2007).
I would just like to figure out what engine is in my 350z so I can figure out if I need to order just a plenum spacer or both the plenum spacer and MREV2.
someone help
Old Jul 25, 2009 | 08:13 AM
soleil's Avatar
soleil
NolaZcc
Vq35de rev-up
Old Jul 25, 2009 | 08:50 AM
juju's Avatar
juju
Originally Posted by Zolid
he could only be so lucky
^ LMAO @ this and the original quote.
ibtl.
Engine(s) 2003-2004
* 3.5 L (210 cu in) VQ35DE V6 287 bhp (214 kW) 274 ft·lbf (371 N·m)
2005 (35th Anv & Track)
* 3.5 L (210 cu in) VQ35DE RevUp V6 300 bhp (220 kW) 260 ft·lbf (350 N·m)
2006
2007-present
* 3.5 L (210 cu in) VQ35HR V6 306 bhp (228 kW) 268 ft·lbf (363 N·m)
Old Jul 25, 2009 | 09:05 AM
Zolid's Avatar
Zolid
^ They're not rated in BHP btw
Old Jul 25, 2009 | 09:06 AM
albaugh81's Avatar
albaugh81
Thanks I didn't know this.
Old Jul 25, 2009 | 09:09 AM
juju's Avatar
juju
Well poo.
Old Jul 25, 2009 | 10:24 AM
johns350's Avatar
johns350
ibtl.
Engine(s) 2003-2004
2006
2007-present
To be clear - the above is for MT only.... Auto 05/06 had the orig DE, not RevUp
Old Jul 25, 2009 | 11:50 AM
christian_wlcp
now that i know the exact engine.. and ive done some research so relax, is my best bang for the buck the motordyne MREV2 and 5/16 spacer or should i go another route. ^ roughly $700????
Old Jul 25, 2009 | 11:59 AM
Caledan's Avatar
Caledan
Since you have a DE engine, the MREV2 is not required. The 5/16 spacer is enough~
Old Jul 25, 2009 | 12:06 PM
kacz07's Avatar
kacz07
I hope you're joking.
If you have the rev up engine, which you do, the Mrev2 will need to be used in combination with the spacer. So yea, buy both.
christian_wlcp
read the top 100 questions thread and it said if you have the rev-up youll need to get both if you want to see gains.
If you are a rev-up owner (7000RPM redline), you will basically only benefit from getting BOTH a 5/16" spacer and the MREV2. If you get the MREV2 only, your mid-range torque will increase but your maximum HP will drop off severely. If you only get the 5/16" spacer, you will not see a benefit. Several dynos have proven that for the rev-up motor, you basically need both the spacer and the MREV2, which will make a lot of midrange torque, without sacrificing too much peak HP.
Old Jul 25, 2009 | 01:18 PM
Chaser720's Avatar
Chaser720
Lemoned Z
You know what else you probalby have... da oil eatin engines.
Search Oil Consuption. You got the, for lack of better terms, nissans **** up engine.
Old Jul 26, 2009 | 07:18 AM
kevin319's Avatar
kevin319
are you saying the 35th anniversary 6spd models have f-ed up engines too?
Old Jul 26, 2009 | 07:41 AM
huyrua's Avatar
huyrua
Kevin319 ^^^ditto on Chaser comments
Old Jul 26, 2009 | 04:17 PM
Chaser720's Avatar
Chaser720
Lemoned Z
We have a winner.
https://my350z.com/forum/engine-and-...iscussion.html
Mine doesnt consume any more though. I fixed it with an LS2.
Old Jul 27, 2009 | 06:01 AM
Caledan's Avatar
Caledan
Oops...my bad , MREV2 is required for the Rev-up along with the 5/16 spacer~ Thnx for correcting me
Old Jul 27, 2009 | 09:13 AM
christian_wlcp
what do u mean u fixed it w an LS2??
Old Jul 31, 2009 | 11:06 AM
driftwood's Avatar
driftwood
google ls2... you will understand really quick
Fixxxercask
Nov 9, 2015 11:10 AM
