350z auto trans jupping rpms
Old Jul 28, 2009 | 07:51 AM
skarakis007's Avatar
skarakis007
Default 350z auto trans jupping rpms
I have an 04 305z with an auto trans if i get on it had sometimes it jumps like 500rpms then drops and pulls
is that tran slip or what
Old Jul 28, 2009 | 07:55 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
what RPMs are ya at when it does this?
Old Jul 28, 2009 | 08:57 AM
skarakis007
Old Jul 28, 2009 | 09:02 AM
The motor turns but the rear wheels do not? Yes that is a automatic transmission problem.
Old Jul 28, 2009 | 09:07 AM
vthao's Avatar
vthao
Sounds like your torque converter is slipping.
Old Jul 28, 2009 | 01:29 PM
rcdash's Avatar
rcdash
check fluid - when's the last time ATF was changed?
Old Jul 29, 2009 | 06:37 AM
Vince@R/TTuning
When u stand on the throttle in the that RPM ranges those automatics have a slight flare that is normal. we see it on the dyno all the time. Best to check ur fluid and everything just to be safe . The flare should only be a couple hundred rpms not like 1000... just to be clear
etkms
Jun 19, 2022 06:30 PM
Ace2347
Sep 22, 2015 03:12 AM
hardkicks
Sep 20, 2015 12:28 PM
ddegrande21
Sep 6, 2015 11:15 AM
