Getting 3rd gear syncro repaired...thoughts on time it will last?
Old Aug 16, 2009 | 05:39 PM
the_dood's Avatar
the_dood
Default Getting 3rd gear syncro repaired...**UPDATED**
Im finally getting my 3rd gear syncro repaired after my warranty finally kicked in.
Anyone have an idea of how long it will last if i baby the car?
Im sure ill have a little fun with it in the beginning but since i heard that it will only last a couple years i guess ill baby the 3rd gear.
thanks dudes.
Old Aug 16, 2009 | 05:49 PM
binder's Avatar
binder
they should put the new version of the syncro in and it should last.
Infiniti just replaced my entire transmission when mine started acting up. I have revision 10 of the 2003 transmission now.
Old Aug 16, 2009 | 05:54 PM
shiftdrift06's Avatar
shiftdrift06
I sure could use one of those...my fifth is on its way out also...94k miles on my 2003...
Old Aug 16, 2009 | 07:20 PM
20,000 miles.
Old Aug 16, 2009 | 08:03 PM
vthao's Avatar
vthao
Originally Posted by davidv
20,000 miles.
It should last you the lifetime of the car. Synchros only wear out when you miss-shift and grind the gears, or don't push in the clutch and try to shift gears.
Old Aug 16, 2009 | 09:00 PM
tecni's Avatar
tecni
not true... syncros wear every time you make a quick shift.
Old Aug 16, 2009 | 09:11 PM
Mike@Blackline's Avatar
Mike@Blackline
i thought that there was NO NONE ABSOLUTELY NOTHING in terms of fixes that were permenant for the 3rd gear issue. not sure though, im just a tard
Old Aug 16, 2009 | 10:30 PM
King350Z's Avatar
King350Z
i don't know. I was reading some guys saying that the new cd009 tranny eliminates that problem entirely
Old Aug 17, 2009 | 07:50 AM
binder's Avatar
binder
mine also had the issue with 5th gear being hard to engage.
I thought my paperwork says "revision 10" in the comments for the transmission but 009 looks familiar.
anyways, it shifts much better than the original transmission. It was replaced around 48k and i have 75k on it currently. It still shifts like butter.
Old Aug 17, 2009 | 07:53 AM
Nexx's Avatar
Nexx
Old Aug 27, 2009 | 01:39 PM
the_dood's Avatar
the_dood
got my car back today and i finally have a 3rd gear and a new clutch.
however, something happened either something is really fugged up or there is a sensor or something that is not plugged because i got no power. pedal to the metal and it hardly accelerates. there is a severe lack of power going on. is wasnt like this before i took it in to the shop for the third gear and i made sure he was aware of that too.
now i wanna settle the obvious, does anyone think there could have been a wire that wasnt plugged back in or something?
Old Dec 27, 2009 | 08:03 AM
gregk's Avatar
gregk
can someone explain what the 3rd gear synchro problem is about. I'm having difficulties with my 3rd gear. Is it still on warranty ?
2003 G35 coupe 6MT
Old Dec 27, 2009 | 10:02 AM
binder's Avatar
binder
2003 G35 coupe 6MT
it's good for 6 years and 60k miles or somewhere in there. The service department should be able to tell you if you give them your VIN.
So depending on when yours was made it might still be covered if you are under mileage.
The issues are grinding into 3rd gear and sometimes 5th gear. Sometimes it won't even allow you to select those gears at all.
Old Dec 27, 2009 | 11:40 AM
my-red-pony's Avatar
my-red-pony
I took my stock tranny in to Nissan and they did my 3rd gear, 3 months later I swapped it for a cd009. Haven’t had a problem with the cd009- IMO the cd009 is a much better tranny.
-OP, Lack of power could be due to the new clutch/flywheel. When they are worn almost to the end it seems faster because there is a little bit less centrifugal weight. could be wrong but that’s just my .02
Old Dec 27, 2009 | 11:43 AM
Jay'Z's Avatar
Jay'Z
7 days.
Old Jun 29, 2011 | 10:37 PM
mcsoap's Avatar
mcsoap
syncros require friction to move, so the more frictions that is applied the faster its gonna wear, due to some bad shifts into 3rd gear, my 3rd gear syncros are starting to.
Old Apr 14, 2019 | 03:13 PM
fflipski's Avatar
fflipski
Check that the crank sensor is plugged in. In limp mode , it should throw codes. Sometimes shop forgot to align the flywheel and can throw a limp mode before it is realigned.
Get the shop to look at it
Old Apr 15, 2019 | 05:10 AM
Painterguy39's Avatar
Painterguy39
You do realize the OP hasnt been on here in 10 years,RIGHT?
Old Apr 27, 2019 | 07:10 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
😂😂😂, OP probably driving a ///M4 or something newer now a days....
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
