running lean
Old Aug 23, 2009 | 07:00 PM
  #41
binder's Avatar
binder
Make sure you talk to the parts department......they are the ones who access the number for you. Just fyi
ya, they are the ones that took 3 times to order me the correct oring for my fuel pump to tank seal. I even pointed it out in the service manual.
Old Aug 24, 2009 | 12:16 AM
  #42
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by binder
pm me your vin number and i'll see if the retards at our local nissan dealership will know how to find the ecu part number.
I doubt they will since they're high school punks, but it's worth a try and tomorrow is my day off from work.
PM sent..
Old Aug 24, 2009 | 02:52 AM
  #43
Chef-J's Avatar
Chef-J
Booooosstt!!
Oh I thought u had person to do it for you. Let me know if blinder local dealer won't give it out, I will try my local.
Old Aug 24, 2009 | 03:22 AM
  #44
maXmood's Avatar
maXmood
Under Boost!
thnx guys.. will let u know Chef-J.
Old Aug 24, 2009 | 08:16 AM
  #45
Chef-J's Avatar
Chef-J
Booooosstt!!
Sent da numba~
Old Aug 24, 2009 | 01:40 PM
  #46
maXmood's Avatar
maXmood
Under Boost!
well.. as u guys know, got 3 numbers in total. and i can't really go ahead with the order with inaccurate information.. hahah, so i guess i'm stuck without a tune >.<
Old Aug 24, 2009 | 06:00 PM
  #47
Chef-J's Avatar
Chef-J
Booooosstt!!
My local didn't even ask me MT or AT, like other dealer asked to blinder. I don't know how all that numbers are diff.
Guess you gotta call for last.
Old Aug 24, 2009 | 06:05 PM
  #48
03threefiftyz's Avatar
03threefiftyz
I have a very good local dealership and if you want I guess I could make a call for you. I got my number from them and it took about 15 seconds, and they knew exactly the number I needed. Just pm me if you want.
Old Aug 25, 2009 | 02:13 AM
  #49
maXmood's Avatar
maXmood
Under Boost!
PM sent...
Old Aug 25, 2009 | 01:39 PM
  #50
binder's Avatar
binder
any news?
Old Aug 25, 2009 | 01:47 PM
  #51
03threefiftyz
My apologies.......I forgot to call today and the parts department is now closed....I will call at lunch tomorrow.
Old Aug 25, 2009 | 01:56 PM
  #52
maXmood's Avatar
maXmood
Under Boost!
no problem..
Old Aug 25, 2009 | 02:14 PM
  #53
Chef-J's Avatar
Chef-J
Booooosstt!!
Maxmood, just logged my cipher today. My second part ( after 27XXX ) starts with CD.
Hope that helps.
Edit:
03threefiftyz,
Is there way that i can look into Rev limiter via cipher? I tried find it but had no luck. (Maybe i can look via osiris tuner?)
Old Aug 25, 2009 | 02:24 PM
  #54
maXmood's Avatar
maXmood
Under Boost!
thnx Chef.. the problem is, with all those part numbers i got, it doesn't seems to match with what Nissan got on their website. there isn't such thing as 27xxx-CFxxx (which are the numbers most of u guys got from the dealer).. i'll just wait for Mike's attempt at getting the number.
about the rev limiter, you can set it with cipher as well as with osiris standard.
just download the manual and read it out.
Old Aug 25, 2009 | 02:38 PM
  #55
Chef-J's Avatar
Chef-J
Booooosstt!!
Well...it doesn't looks like i can log on osiris. Gotta look over again...Maybe cuz i only had dyno tune? I remember jared told me, cipher won't do much in my case. If i want to real log on to change things, he said i need a tuner.
Thanks for an advice.
Old Aug 25, 2009 | 02:52 PM
  #56
maXmood's Avatar
maXmood
Under Boost!
to do a whole new map, you'll need the Tuner. otherwise, Standard is ment for e-tunes/refined maps from Uprev. Cipher on the other hand can do as little:
  • Target Idle RPM
  • +/- 2 degree static timing adjustment
  • Cylinder power testing
  • Clear Learned Fuel settings
  • Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
  • Fuel Pressure purge
  • Ethanol Adjustments (if vehicle is equipped)
  • Coolant Test
Supported Parameters:
Below is a short list of available data parameters...
  • Engine Speed - RPM
  • Throttle Position Sensor
  • Vehicle Speed
  • MAF Sensor
  • Calculated Load Value
  • Oxygen Sensor
  • Ignition Timing
  • Accelerator Position
  • Wide Band A/F Voltage (equipped vehicles)
  • Coolant Temperature
Old Aug 25, 2009 | 03:07 PM
  #57
03threefiftyz
You need the tuner version to adjust rev limit. Only thing you can do with cipher besides diagnostic logs is bump idle up ~250rpm and adjust base timing -/+ 2 degrees.
Old Aug 25, 2009 | 03:14 PM
  #58
maXmood's Avatar
maXmood
Under Boost!
for real???
u can't even adjust the limiter with osiris standard?
  #59
Chef-J's Avatar
Chef-J
Booooosstt!!
^ Gotcha. Thanks.
Edit: One more, What's real benefits from just adjust -/+2 timing?
Old Aug 25, 2009 | 03:20 PM
  #60
03threefiftyz
Originally Posted by Chef-J
^ Gotcha. Thanks.
If your car is dyno tuned I wouldn't play with it. I bump my timing +2 when I run 100-104oct fuel, but I wouldn't on pump. If it was tuned you can be sure that the tuner is likely running as much timing as is beneficial.
for real???
When you get the reflash you tell them what you want the rev limit to be. Mine was 7000. If you get the car dyno tuned with Osiris the tuner can set it to your specification.
