running lean
Old Aug 21, 2009 | 04:58 PM
maXmood's Avatar
maXmood
Under Boost!
Default running lean
I dyno'ed the car a year back when it was stock (attached sheet).
i don't know why it was running lean, and i'm not sure what a stock 350z should be running the AFR at? and what possibly could cause this?
i've searched the forum for similar issue, but can't find any.
dyno'ed on DynoJet
vid of the dyno: http://www.youtube.com/watch?v=go4j2nz8k-I
Old Aug 22, 2009 | 01:21 PM
maXmood's Avatar
maXmood
Under Boost!
BumP... 100 views.. no reply.
Old Aug 22, 2009 | 01:29 PM
binder's Avatar
binder
looking at the dyno it looks fine except it should be richer when you got WOT. Normal throttle usually keeps it about 14.7 best as possible.
General rule of thumb is to keep it below 12.0 at WOT all the way to redline. I keep mine about 11.3 above 6psi.
I'm not sure what the a/f is supposed to be on a stock car. If it's the stock ecu controlling it i guess you aren't responsible.
Old Aug 22, 2009 | 02:08 PM
maXmood's Avatar
maXmood
Under Boost!
so, basically you're saying that 14.7 is suppose to be normal (stock form). and at WOT, it should be richer than 14.
altho i thought 11 is rich, does that mean 12 is suppose to be the best in all situations (including FI setups)?
on a side note, i'm getting an HFC and an exhaust installed soon, and i'm sure i'll be running pretty lean. shouldn't the ECU be able to refine the parameters for a proper mixture?
Old Aug 22, 2009 | 05:21 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
What i remember was 12.8 or 12.5 at WOT (correct me if i'm wrong) and FI is diff.
Old Aug 22, 2009 | 05:39 PM
03threefiftyz's Avatar
03threefiftyz
12:8-13:0 is ideal for NA.......My first un-tuned pull looked similar to that. Having a 12:8 A/F allows for some added timing as well.
Old Aug 22, 2009 | 06:00 PM
maXmood's Avatar
maXmood
Under Boost!
alright, what could cause that?
Old Aug 22, 2009 | 06:11 PM
03threefiftyz
Honestly, it could be any number of things. You plan to have the car tuned soon anyway.....correct?
Old Aug 22, 2009 | 08:54 PM
binder's Avatar
binder
stock ecu
and when you add your hfc's and other stuff the ecu should automatically adjust for the needed fuel. That's why there are 4 o2 sensors on the car. This works to an extent. A retune would provide the most power out of the situation.
Old Aug 22, 2009 | 10:04 PM
maXmood's Avatar
maXmood
Under Boost!
yea, planning to get an osiris. and i might probably end up dyno tuning the car..
Originally Posted by binder
stock ecu
that actually makes more sense to why my car acts differently..
i mean, since this car was imported from the US, the ECU is set to burn the fuel @ a certain rate (set in the ECU for the US product). and since we have a different octane level here, it won't be able to burn the fuel at the same rate. that could be the reason making it lean.
am i making any sense?
Old Aug 23, 2009 | 04:25 AM
binder's Avatar
binder
i don't think octane would be the reason, but a difference in fuel could definitely be the reason.
did your elevation change drastically? that could also change.
You might want to take the battery cable off of the battery which allows the ecu to reset. It will take off the memory of your fuel trims and "relearn" your driving.
Judging by what everyone else is saying your a/f isn't bad at all for NA. I'm not familiar with the a/f ratio of this car when it's not boosted.
Old Aug 23, 2009 | 05:33 AM
maXmood's Avatar
maXmood
Under Boost!
actually we're at sea level in terms of elevation. i mean, we're a small island surrounded with sea from every direction, and not a single mountain. humidity is always high and summer heat is like 6 months a year.
in terms of octane level, we're running 95-96RON (which is 90-91AKI) at the stations.
i'll defo. reset the ecu once i get both mods installed.
Old Aug 23, 2009 | 07:39 AM
binder's Avatar
binder
also, i just remembered. If you have an exhaust system that isn't "straight through" design doesn't taking a tailpipe reading show on the lean side of a/f? I could have swore someone mentioned that it did.
I don't think the octane is the problem with the a/f. If it has a higher ethanol content it might not be supplying enough fuel per unit volume or the a/f reading on the o2 sensor could be off due to the odd mixture of fuel.
Old Aug 23, 2009 | 08:47 AM
maXmood's Avatar
maXmood
Under Boost!
any chance it could be the injectors not pumping properly/clogged? since the normal AFR @ 14.7, the injectors are spraying the minimum gas required, but at WOT the injectors should be spraying at a higher rate, and if the injectors are clogged, the AFR will be lean since the air will be more than fuel.
is that possible?
Old Aug 23, 2009 | 09:07 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
In my head, That is possible.
Old Aug 23, 2009 | 09:42 AM
binder's Avatar
binder
but that doesn't fit the reason why his a/f lowers in higher revs. That proves that the injectors are capable of pushing more fuel.
i would just have it retuned
Old Aug 23, 2009 | 09:59 AM
maXmood's Avatar
maXmood
Under Boost!
that's why i thought the injectors could possibly be.
Old Aug 23, 2009 | 10:25 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Oh i thought he was just asking about general A/F. (Not about his dyno)
Old Aug 23, 2009 | 10:27 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
I think your dyno looks fine, not perfect but nothing to hurt any. What mods do you running?
Old Aug 23, 2009 | 11:50 AM
j.arnaldo's Avatar
j.arnaldo
Isn't the ECU supposed to monitor/adjust that??
