Not Much Power to Start The Engine
Old Sep 9, 2009 | 10:45 PM
swatcsj's Avatar
swatcsj
Smile Not Much Power to Start The Engine
I have 06MT with 25,000 miles on it. I changed the engine oil (Mobil 1 5W-30 Full Synthetic) and STP Fuel Injector Cleaner recently.
Since a week ago, when I try to start the engine from the cold, the starting sounds seem like there is not enough power to start the engine. But It seems okay once the engine is warmed up. Sometimes, I have problem with starting the engine. I have to push the clutch pedal several times to start the engine. I think it is related to the little switch (on the wall) behind the clutch pedal.
Just want to know any idea from ya'll.
Peace~
Old Sep 10, 2009 | 07:13 AM
VO...'s Avatar
VO...
Administrator
Your battery may be starting to give out, if it's a weak starting problem you're having. If nothing is happening when you turn the key, as you have suggested by "having to push the clutch several times", you might have another problem. Like the clutch switch you described...
Old Sep 10, 2009 | 09:31 AM
swatcsj's Avatar
swatcsj
My battery is at 14 on the gauge which is above the middle.
Then I guess the clutch switch doesn't transfer the power correctly ?
Its weird that if the engine is warmed up, it seems no problem.
Old Sep 10, 2009 | 09:32 AM
vthao's Avatar
vthao
It's probably a weak battery. Even if the clutch switch isn't fully functional, when it is your car should start right up without having to slowly turn before firing up. Change the battery first
Old Sep 10, 2009 | 09:37 AM
gabez33's Avatar
gabez33
yeh +1 on the battery thing, your gauge cluster just reads running voltage
Old Sep 10, 2009 | 09:46 AM
swatcsj's Avatar
swatcsj
I went to local Autozone to check the battery status.
The battery condition was excellent
I might have to check the ignition switch at the local nissan service department
Old Sep 13, 2009 | 08:59 AM
swatcsj's Avatar
swatcsj
The problem was the clutch switch pedal position switch. I bought the part from Nissan dealer and did DIY. Just working good now.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
