Power steering pump!
Old Sep 18, 2009 | 12:11 AM
TittieZ's Avatar
TittieZ
Default Power steering pump!
Ok, so one day after doing a few donuts in a deserted parking lot, my power steering decided to go weak on me. I was curious if anyone else has ever had a similar experience?!
I asked the dealer and they quoted me $800 for a new pump, but I have done a PS pump before, and most of the time they aren't too difficult. Has anyone else swapped a pump? If so, is it as straight forward as any PS pump?
Old Sep 18, 2009 | 01:17 AM
calin's Avatar
calin
Sorry I can't help you with your problem, but I like your username
bump for TittieZ
Old Sep 18, 2009 | 06:13 AM
plumpzz's Avatar
plumpzz
Check the fluid level, belts before anything. The PS pump will leak before it breaks usually. PS pumps are cheap adn the install is is easy from what I can see underneath the car. If you can change a belt, you can change a PS pump.
Old Sep 18, 2009 | 11:54 PM
TittieZ's Avatar
TittieZ
Yeah I thought the same thing, I was up to par on the fluid levels, and there doesn't seem to be leakage but still no power steering. Oh well, I was thinking the same, it looks easy enough. Thanks!
Depravity
Oct 1, 2015 04:49 PM
