need this fuel part... HELP!
Old Sep 23, 2009 | 01:00 PM
ezpotato's Avatar
ezpotato
Default need this fuel part... HELP!
okay guys, this is along the passenger side of the engine bay, towards the bottom right. i'm assuming this is the stock fuel line? It's leaking bad, i need to replace the highlighted hose/line.
any help?
Thanks guys!
Old Sep 24, 2009 | 04:59 AM
shiftdrift06's Avatar
shiftdrift06
Im assuming your vortech?
Make sure the silver metal part that connects to the stock hardline its pushed in all the way.
To remove it, youll need the quik disconnect fuel line tool.
Your rubber hose is held on by those vortech clamps, ditch them and buy proper size fuel injection clamps, and double up on them right there.
Old Sep 29, 2009 | 09:48 PM
ezpotato's Avatar
ezpotato
thanks for the the info... but is that hose stock? if i rip it off can i take it to the dealership and get a replacement? cause it is spraying fuel so it's cracked.
Old Sep 30, 2009 | 10:26 AM
shiftdrift06
The rubber is not stock and the silver piece (quick connect fuel coupling) is not stock, that is Vortech parts. You can get the rubber hose from an auto store, (5/16 fuel injection hose), it also good to replace the crimp clamp too with real fuel injection clamps.
The metal hardline coming from the gastank is stock. It goes on the inside of the silver piece. You will need a "quick connect fuel line disconnect tool" to detach apart from each other.
Make sure it is pushed ALL the way in, It should make a "click" noise.
