More throttle body issues...
Old Sep 25, 2009 | 04:12 PM
JAM3Z's Avatar
JAM3Z
Phenom
Default More throttle body issues...
Well, I replaced my throttle body unit, but the car still has issues with throttle response at times. What else can I do to get to the bottom of this? This is getting to be a pain in the ***, and any ideas would be helpful...
Old Sep 25, 2009 | 04:13 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you do the reset and learn procedures?
Old Sep 25, 2009 | 04:14 PM
JAM3Z's Avatar
JAM3Z
Phenom
I thought that the car did that automatically. What do I need to rectify this?
Old Sep 25, 2009 | 04:17 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
http://www.technosquareinc.com/350reset.htm
do the last two
sorry if you tried calling...was updating to 3.1 software on the phone
Old Sep 25, 2009 | 04:23 PM
Jay'Z's Avatar
Jay'Z
Reset your ecu, but you most likely need an uprev reflash!!
Old Sep 25, 2009 | 04:27 PM
JAM3Z's Avatar
JAM3Z
Phenom
Why? The car ran perfectly for a long, long time without it.
Old Sep 25, 2009 | 04:41 PM
JAM3Z's Avatar
JAM3Z
Phenom
Because your idle is most likely super low and you would raise it back up to oem spec.. Not only that you changed injectors/fuel system from OEM.. I had a **** load of problems idle/car shut off before I got the uprev Osiris tune, after that I have never ever had any problems..
The issue is that the throttle is unresponsive on an irregular basis. The revs climb super slowly, no matter how much throttle input I give it.
Old Sep 25, 2009 | 04:49 PM
Jay'Z's Avatar
Jay'Z
You have UTEC right?
Old Sep 25, 2009 | 04:51 PM
JAM3Z's Avatar
JAM3Z
Phenom
^Yes.
Old Sep 25, 2009 | 04:57 PM
Jay'Z's Avatar
Jay'Z
I hated the utec, it would take over so abruptly.. It wasnt smooth.. Like I said, if you got a reflash or Osiris tune.. It would be smoother, you also should log your driving for a few minutes, make sure your not tapped out with your MAF.. I was.. So I upgraded it..
Old Sep 25, 2009 | 04:58 PM
Jay'Z's Avatar
Jay'Z
Unless your clutch is going out.. Since you say its unresponsive and doesnt climb rpm.. Have Sharif/FP check it out since ur local...
Old Sep 25, 2009 | 05:02 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
JayZ I think your thinking too hard here.
James replaced his failing TB with a new one and is having issues still. It is possible because the new TB has not be learned by the OEM ECU. I dont think the UTEC is the issue.
James, have you done the procedures above?
Old Sep 25, 2009 | 05:04 PM
Jay'Z's Avatar
Jay'Z
Ok Cux, you seem to be the man lately.... You can take over...
Old Sep 25, 2009 | 06:18 PM
JAM3Z's Avatar
JAM3Z
Phenom
Not yet. I'm drinking now, so I may hold off until sunday. We're going to Petit LeMans tomorrow at Road Atlanta. You should come.
Old Sep 25, 2009 | 06:45 PM
JAM3Z's Avatar
JAM3Z
Phenom
I appreciate the help Chris and Jay. I'll post back up when I have something more.
Old Oct 2, 2009 | 11:02 AM
JAM3Z's Avatar
JAM3Z
Phenom
Ok, I've done the relearn procedures a few times now and no luck. The throttle will respond fine for a couple of minutes, and then it will just go back to its old unresponsiveness. This is seriously getting ridiculous, and I'm beyond frustrated about this.
What else can possibly be the problem?
Old Oct 2, 2009 | 11:15 AM
SexyRob's Avatar
SexyRob
I know it probably doesn't happen often but maybe its not the TB, its the switch on the pedal sending the signal? if it isnt an ECU issue and its not a TB issue you just have to consider everything else in the loop.
Old Oct 2, 2009 | 11:24 AM
psychoballistic's Avatar
psychoballistic
Its going into limp mode correct? Your slip light comes on the dash right? I think Sexyrob is thinking of the APP Sensor which is something i've been battling with for some time. It's the frist thing I thought of after reading your post.
Old Oct 2, 2009 | 11:28 AM
JAM3Z's Avatar
JAM3Z
Phenom
^I'm not clear on what you're talking about precisely.
Old Oct 2, 2009 | 09:33 PM
SilverJDMCoupe's Avatar
SilverJDMCoupe
Have you tried cleaning your MAF Sensor??
