Engine and Trans removal
Old Oct 5, 2009 | 08:25 PM
LSX-PWR's Avatar
LSX-PWR
Question Engine and Trans removal
Can I remove the engine and trans together? I have the whole front end removed mines the fenders, drive shaft and other brackets as well. Can you all give me some tips on removing the shifter and anything else i need to remove from the trans like the clutch master cylinder lines ex....?
Old Oct 6, 2009 | 06:14 AM
350z 6spd's Avatar
350z 6spd
You can remove them together just be careful of the hard lines on the steering rack as you're trying to angle and remove the whole assembly.
Old Oct 6, 2009 | 06:21 AM
GT-Z's Avatar
GT-Z
just take the front of the car off & pull it str8 out!!!!!
Old Oct 6, 2009 | 01:31 PM
LSX-PWR's Avatar
LSX-PWR
She's ready to come out, the only thing is I can't get the dang shifter off. How do I get the sob off? Some times the smallest things are the hardest.
Old Nov 15, 2009 | 01:19 PM
binder's Avatar
binder
did you get the shifter off? i would hope yes since it's been a month.
Old Nov 15, 2009 | 03:26 PM
QuadCam's Avatar
QuadCam
the shifter is very easy.
once you remove the trim piece from the center console, you will remove the 4 bolts that hold down the noise isolation boot. after taking those bolts out, lift up the boot and you find 3 more bolts......take those out. that all for inside the cabin area.........oh yeah, I assumed that you took the shift **** off prior to starting the shifter removal.
next, you need to move underneath the car. if I remember correctly, there is just one bolt to remove. it is where the shifter attaches to the shift rod assembly.
now....go back in the cabin and pull the shifter straigh up and out of the car. make sure not to lose the reverse lockout spring!
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
