3.9 or 4.08 gears
Old Oct 13, 2009 | 05:17 PM
TheBlue350z's Avatar
TheBlue350z
Default 3.9 or 4.08 gears
my next mod i am saving up for are a set of gears. i heard alot of talk that the 4.08 gears are very diffcult setup. i am planning to have it installed at a well known performance shop near my area. is it worth getting the 4.08's or should i get the 3.9 and stay save?/
Old Oct 13, 2009 | 05:27 PM
03threefiftyz's Avatar
03threefiftyz
4.08's are cheaper....both equal in terms of installation. If your redline is 7000+ I say 4.08's, but if you are limited to under 7000 3.9's might be better. This is only my opinion....based on the fact that 4.08's can require a shift to 5th in the 1/4 mile. If you are basing this on "street" performance or circuit racing than the 4.08's will shine.
Old Oct 13, 2009 | 05:31 PM
dsmZ's Avatar
dsmZ
love my 4.08's!
Old Oct 13, 2009 | 06:23 PM
Emski's Avatar
Emski
Be aware that 3.9 gears are significantly more expensive becasue of limited production.
Most will recommend going 4.08 regardless.
Old Oct 13, 2009 | 06:35 PM
03brembo's Avatar
03brembo
4.08s your first gear its pretty damn quick, and normal street driving is +1 gear now.
Old Oct 13, 2009 | 06:36 PM
spnall4's Avatar
spnall4
Y so SrS!
I love my 3.9 fd
Old Oct 13, 2009 | 06:39 PM
03brembo's Avatar
03brembo
LOVE my Four-0-eightS
Old Oct 13, 2009 | 06:41 PM
Goku350z2007's Avatar
Goku350z2007
what gears does a base model 2007 z has?
Old Oct 13, 2009 | 06:54 PM
03threefiftyz
3.5 for 6mt
Old Oct 13, 2009 | 07:42 PM
TheBlue350z
i have a 06 mt w 31k w no vdc.. will this setup be ok for a set of gears to be daily driven.
does anyone know the average price for installtion on a set of gears?
what about 3.9 or 4.08 with a turbo?
Old Oct 13, 2009 | 08:00 PM
TheFarmer's Avatar
TheFarmer
I would go with 4.08s
Old Oct 14, 2009 | 05:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
install costs will vary by shop, but expect to pay $400-$600
Old Oct 14, 2009 | 06:44 AM
TheBlue350z
are 3.9 & 4.08 used on n/a.. do they would well if i decided to get a turbo
Old Oct 14, 2009 | 06:48 AM
Z1 Performance
Former Sponsor
it would depend but generally speaking, no
Old Oct 14, 2009 | 09:42 AM
fabcas311's Avatar
fabcas311
wow!im lucky my mechanic is only asking for $150-200!
Old Oct 14, 2009 | 11:45 AM
GeauxLadyZ's Avatar
GeauxLadyZ
For that price.....................................he better be good.
Ring and pinions are a VERY tedious install and definetly require someone that has done it before, pref quite a few times.
Hope your guy knows what he is doing....
Instances of shops fuking up installs on the F/Ds are a dime a dozen, brosef.
Old Oct 14, 2009 | 11:49 AM
pchio's Avatar
pchio
I hope you are also lucky that they have done it right by measuring the gear back lash and preload.
Old Oct 14, 2009 | 12:08 PM
uglyduc's Avatar
uglyduc
Went with the 3.9 on the HR, paid around 500 installed.
The install should not differ between a 3.9 or 4.08. Same process just different gearing.
Might want to look into finding a pumpkin with a 3.9 or 4.08 installed already, it might be cheaper and you'll have your 3.5 to swap back in when you go TT.
Old Oct 14, 2009 | 12:28 PM
fabcas311's Avatar
fabcas311
i think he knows what hes doing...he installed my previous 3.9fd and couple of my friends.
Old Oct 14, 2009 | 02:12 PM
costilla's Avatar
costilla
Man, if joesph is charging only that much, I know where I'm going. But he is good tho.
