04 motor in 05 chassis
Old Oct 19, 2009 | 02:45 PM
white05350's Avatar
white05350
Default 04 motor in 05 chassis
will 04 motor work in 05 chassis? i mean will the harness work? and i only have the 05 ecu. what do i need to know before i do this?
Old Oct 19, 2009 | 03:18 PM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Maybe / maybe not. Is it a 2004 or a 2004.5 motor, there may be differences and the harness may be different. A 2004.5 will be closer to a 2005 as the 2004 is closer to the 2003.
A whole lot more.
Old Oct 19, 2009 | 04:01 PM
white05350's Avatar
white05350
A whole lot more.
is there a way to find out if its 04 or 04.5? cuz i just got the motor cant check the label since the car is dismantled.
Old Oct 19, 2009 | 04:54 PM
plusONETEN's Avatar
plusONETEN
did you blow your engine?
if so, and if neither one is the rev-up version, you might be able to just attach all the crap that belongs to your car... maf, throttle bodies, o2 sensors, injectors... etc etc to the other engine.
if that is the case, though, someone else here will know.
all im saying is that if you post more info on what exactly youre working with here you might find out that theres an easy way to do what you wanna do...
Old Oct 19, 2009 | 05:42 PM
white05350's Avatar
white05350
neither one is a rev up. the current engine is no good. needs some work to fix it. i just got another engine with tranny that is of an 04 z. both are manual.
Old Oct 20, 2009 | 12:38 PM
white05350's Avatar
white05350
the motors production years is 2003/7
will this work on a 2005?
white05350's Avatar
white05350
the motor production year is 2003/7
Rowlett
Misc.
Oct 2, 2015 10:38 AM
